View Poll Results: How often do you change your oil?
Every 3000 miles
20.59%
Every 5000 miles
8.82%
X number of times per year
38.24%
32.35%
Voters: 34. You may not vote on this poll
Old Feb 12, 2019 | 05:09 AM
There was a thread recently on how many miles/year you drive your Olds. I wondered how often folks change the oil in their Olds? I change the oil in my Olds twice a year (once in the spring and once in the fall) regardless of mileage.
Old Feb 12, 2019 | 05:42 AM
chip-powell's Avatar
I change the oil in my Olds every Spring, regardless of miles driven. I usually put less than 2000 a year on her anyway. For the rest of my cars that are far newer, I change their oil and rotate the tires every 6000 miles.
Old Feb 12, 2019 | 06:47 AM
442Harv's Avatar
One a year, I drive less then 1000 miles a year.
Old Feb 12, 2019 | 07:27 AM
ELY442's Avatar
My daily driving car, 2002 Bravada, I change every 2500 miles. My 70 Cutlass convertible, I have not changed it yet because I dont put more than 10 miles a year. I just drive it around the block. My other 70 Cutlass, I just installed a rebuilt motor last year and the oil is still new. I have not driven it yet. Waiting for a better weather to burn rubber.
Old Feb 12, 2019 | 08:00 AM
Burd's Avatar
I go every 3 years now. Every year I toss good oil out. So it’s like 1,500 every 3 years.
Mobil1, I can of zinc, Baldwin filter. Also my garage is heated, if it was out in the cold and humidity I’d prob still go every year.
Old Feb 12, 2019 | 08:02 AM
tonymueller55@gmail.com's Avatar
3,000 miles or once a year.
Old Feb 12, 2019 | 08:25 AM
Usually once a year. If there is a reason to change it more often ( engine work) or extra miles obviously it’s change more often
Old Feb 12, 2019 | 08:38 AM
Charlie Jones's Avatar
Phantom Phixer
I use Mobil 1 . So it's every 10,000 miles or yearly .
Old Feb 12, 2019 | 08:55 AM
Maybe I should start doing the same. Either that or run the waste motor oil through my diesel truck. I'm too chicken though, I wouldn't want it to coke up my injectors.
Old Feb 12, 2019 | 11:06 AM
My car has only gone 700 miles in the past 10 years. Haven't changed the oil or filter yet. Probably will this spring though.
Old Feb 12, 2019 | 11:30 AM
jaunty75's Avatar
As often as I change my underwear. Every 10 years, even if it doesn't need it.
Old Feb 12, 2019 | 12:23 PM
I typically change the oil every winter. When I drive a lot it's usually about 4000 miles a year, which is about the mileage for an oil change. If I don't drive that much in the year, it's about time (12 months) for an oil change.
Old Feb 12, 2019 | 12:24 PM
rustyroger's Avatar
'87 Delta 88 Royale
Unless you plan on putting the oil in the diesel tank I don't see how it would affect the injectors?.
Roger.
Old Feb 12, 2019 | 06:43 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Every spring on both the Olds, every fall on my Dakota and every 10,000 or so km, just over 25% on left on the oil monitor on the Challenger GT, full synthetic and will get that for life, either 0W20 or 5W20.
Old Feb 12, 2019 | 07:01 PM
1971 Olds CS 350 = 3K miles
2003 Ford 250 Diesel = 5K miles
2010 Indian Motorcycle 105 = 3K miles
2009 John Deere Z225 = x1/yr
2004 Troy-bilt TB 554 = x1/yr
Old Feb 13, 2019 | 03:16 AM
1970cs's Avatar
Lansing built
70 Supreme 1x year with Q.S. defy
04 Alero 1x every other year with full synthetic
14&17 Silverados every 5K miles with full synthetic
12 Cruze 5k with syn blend
all power equipment 1x year conventional
Pat
Old Feb 13, 2019 | 04:06 AM
jensenracing77's Avatar
Every 3 years or so..... I never get to 3000 miles on the oil changes. I have gone longer if the car is only started a time or two a year. Just be sure the oil (not just the water) gets to operating temperature every time you start it. Many people will start their car in the winter to either move it or just to get oil pumping through it thinking they are doing the right thing. If you do not let it get good and hot then you are likely doing more harm than good. The exhaust also needs to get fully hot all the way back or you will have water sitting in it rusting it out.
My daily drivers go around 6000 miles using Mobil 1. The van I drive back and forth to work is an experiment for me. I would have to look it up but I changed oil in it 1 time in around 25,000 miles.
Old Feb 13, 2019 | 05:01 AM
Correct Roger. There are folks that run Waste Motor Oil as fuel in old diesel engines. They're braver or perhaps just richer or dumber than I am.
Old Feb 13, 2019 | 05:52 AM
Old school diesel engines people did this all the time. Add a gallon of used oil to about 50 gallons of fuel. You could go richer than that on many of the old school diesels and not hurt a thing. I would never do that on modern diesels. EPA ruined them
Old Feb 13, 2019 | 11:24 AM
droptopron's Avatar
delete
Once a year @ spring start up
z11375ss
Jul 16, 2016 08:08 PM
Longhorncutlass
Jan 5, 2014 01:23 PM
kevin.horton
Jul 8, 2011 04:12 PM
71 Cutlass
Sep 10, 2010 07:32 AM
bcg88
Apr 9, 2008 11:24 AM
