how do i adjust my valve?
Old Feb 3, 2014 | 05:09 PM
SD72cutlass's Avatar
my cars been running solid but has a loud ticking sound, which ive narrowed down is under the valve covers, its a 1972 350 rocket orginal but has had a rebuild, ive watched lots of youtube videos and read up on the subject but want to make sure i do it correctly
THANK YOU
Old Feb 3, 2014 | 05:18 PM
tru-blue 442's Avatar
Old School Olds
Sorry, no adjustment.
Check for worn out rockers
or a cracked or broken bridge.
It could also have a mushroomed push rod.
Did they replace cam and lifters
on this rebuild? You may just need
to go back and tighten the rockers up.
Old Feb 3, 2014 | 05:23 PM
Oldsmaniac's Avatar
This is correct but the rocker bolts should never come loose so it is doubtful they need tightening. Most likely you need to replace the worn rockers and bridge. Since the bridge holds 2 rockers they should be replaced as a set.
Old Feb 3, 2014 | 08:53 PM
X4 on the rockers and stands. They can be had at your local parts store.
Old Feb 4, 2014 | 06:45 PM
yes the cam and lifters were replaced and i have yet to take the valve covers off to see if it could be any of the above. i noticed its louder under the engine then the top, i thought it might be the crankshaft bearing but i hear thats more of a knocking sound, this is a distinctive ticking sound and ticks more with acceleration
Old Feb 4, 2014 | 06:46 PM
Old Feb 4, 2014 | 07:17 PM
Old School Olds
If it sounds like it is more in the middle
of the engine, my guess would be a bad lifter.
I would begin by pulling the valve covers off
and see if you have any loose or cracked bridges.
This way you can check for bad pushrods. Also
make sure that none of them are stopped up.
If oil can't flow through them, tik,tik,tik.
Old Feb 6, 2014 | 06:06 AM
Railguy's Avatar
I'd be sure that it wasn't a exhaust leak first.Than you could try longer push rod-rods.I saw someone once use a hammer handle holding down on the rocker to see exactly which one was making the noise.
railguy
Old Feb 6, 2014 | 07:40 AM
455man's Avatar
I had a baffle come loose in the valve cover and one of the rockers was tapping it. That's probably a rare case though.
Arrowstorm
Jan 27, 2015 03:38 PM
bryndalfly
Jun 2, 2010 07:36 AM
84oldsDelta88
Dec 11, 2009 06:19 AM
wmachine
Jul 31, 2009 02:32 AM
74 Omega
Drivetrain/Differentials
May 26, 2008 10:43 AM
