How can I tell an original OEM W25 hood from an aftermarket one at a swap meet?
Old August 26th, 2016, 07:39 PM
Hurst/Olds 73/74's Avatar
I'm going to a local Oldsmobile show this weekend and will be looking for a 1970 OAI W25 hood. How can I tell an original from aftermarket? What is the current value on them? I know a repro from Thornton's is around $2500.
Hurst/Olds 73/74 is offline
Old August 28th, 2016, 09:39 AM
Shaking out the cobwebs..
midrange's Avatar
The factory one will have a stamped steel under frame. A cheap aftermarket one will be all fiberglass that is formed and shaped to loosely resemble a frame.
I've never seen a Thornton in person, while they do have a stamped steel frame, I can't verify any signs to look for on them.
As far as value, I've seen originals listed starting at $1000 needing some repair, all the way to $3000 for one in excellent shape.
midrange is offline
Old August 28th, 2016, 09:51 AM
66-3X2 442's Avatar
One thing an oem hood has is,just inside the scoop opening there is a hole on each side that looks like there was going to be a door/flap of some kind but not used. I'm not sure if the Thornton hoods have that provision or not.
66-3X2 442 is offline
Old August 28th, 2016, 10:35 AM
344879M363895
70-442-W30's Avatar
Just went out to the garage and took some pics for you to illustrate. One thing I noticed is there is an area on the outer edge of each seam toward the front. Possibly an adhesive of some kind. It is brown in color. You could look for that line also and that would identify a real deal.
Pics:
70-442-W30 is offline
Old August 28th, 2016, 04:33 PM
Thank you! That was really good information and the photos were over-the-top! I really appreciate it! This is a great group of people, always willing to share info with the next guy.
Old August 28th, 2016, 05:15 PM
344879M363895
70-442-W30's Avatar
Yes, these guys know what they're talking about. If there are any more pics you want of it, like on the inside, let me know.
Old August 28th, 2016, 07:38 PM
Once Olds Always Olds
Troys Toy 70's Avatar
I don't know if that adhesive was on all hoods. Maybe, it was, but after time they fall out. Here are two pics of hoods without it. The yellow one has been repainted in its life, the white one is original.
Troys Toy 70 is offline
Old August 28th, 2016, 07:40 PM
Another pic of the yellow one
Old August 30th, 2016, 10:53 AM
The Bug Man's Avatar
Dont forget the formed wire mesh (to keep trash and small birds out of the breather) on the under side of OEM units
The Bug Man is offline
Old August 30th, 2016, 11:54 AM
344879M363895
70-442-W30's Avatar
Yeah, that really sharp invention that loves to eat up drying towels and fingers. HA!
banny
April 27th, 2023 01:03 PM
jonesolds442
July 11th, 2019 02:28 AM
twilightblue28A
April 17th, 2016 11:34 PM
teqdave
Body work
December 1st, 2013 09:29 AM
oldsmobilty
November 30th, 2013 09:55 AM
Quick Reply: How can I tell an original OEM W25 hood from an aftermarket one at a swap meet?
