How Cadillac made their cars quiet in the '60's
Old Nov 24, 2019 | 09:40 PM
cfair's Avatar
I was in an old style boneyard on Friday. There's a lot of learning to be gained from looking at old cars and how they were made.
On my mind that day was what made Cadillacs different from other GM makes in terms of quietness. Turns out part of their deal was more seals than other GM brands.
I got some pictures to get a record of what they did that I could apply to my big Olds cars. The takeaway was that they used some additional seals & plates to dampen noise that Olds did not. I thought that was interesting. Here are some shots of decaying Caddies that might give you ideas too.
Here are some door jamb plates that they built into a 65 Sedan de Ville. These look mostly decorative, but add a nice bit of finish to the door jambs:
1965 Cadillac door jamb cover. Should be a decent starter template for an Olds, Pontiac or other GM's. The nuts are 5/16's"
From the front of the car:
These covers were metal. This one shows surface rust. 60's nice metal, not plastic.
They won't be too hard to gin up in aluminum & paint body color for a nice touch. My thought at the moment is to connect the inner edge to the body and line the outer edge in rubber seal to get a nice look and some noise reduction. Mock it up in cardboard for dimensions, then cut light gauge aluminum, paint & fit. Could be a fun saturday.
Here's a shot of mastic rubber cowl to front fender seals from a late 60's Eldorado. I suspect these dampened engine noise going to the cabin a bit. The material looks identical to what Olds used to surround radiators in 1966 and direct air through the rad. instead of around it.
Part of how Cadillac was "Standard of the World" long ago. Additional noise seals. Cool.
Symmetric on the passenger side:
Passenger side Cadillac cowl to fender rubber mastic seal. Not too hard to cut and attach.
Fusick sells this stuff by the sheet for not too many $. Should be another fun, quick project.
The only additional thing I know that's not captured here is that Caddy used additional flap seals on their door bottoms to keep out wind & water. They sat screwed into the door steel between the door panel and the flap hung down into the void between the door bottom and door sill.
I hope at least some of you think this is as interesting as I do. I like the idea that they built additional value into the higher priced brand rather than just badge-engineering it.
cheers
Chris
Old Nov 25, 2019 | 05:20 PM
dennis_30281's Avatar
My 1962 Starfire has the same hinge covers and mastic fender seals.
Dennis
Old Nov 25, 2019 | 05:59 PM
cfair's Avatar
Very glad to hear this.
To your knowledge, were they factory?
Old Nov 25, 2019 | 06:06 PM
Quiet
Yes
Old Nov 25, 2019 | 06:25 PM
Yellowstatue's Avatar
My '69 GMC has fender seals also.
Old Nov 25, 2019 | 07:36 PM
cherokeepeople's Avatar
my 64 starfire had the hinge covers and fender seals also.
Old Nov 26, 2019 | 09:53 AM
anthonyP's Avatar
Very interesting. Guess it was part of the Lincoln v. Cadillac v. Imperial war for the King of the Hill title that was at its height from the 50's through the 70's.
Old Nov 26, 2019 | 02:15 PM
Oldsmaniac's Avatar
My 66 Starfire had the heavy tar-like pads on the floor under the carpet. I replaced them with new ones and new carpet. I bet that made for a quieter ride, it was nice.
cfair
Nov 14, 2019 09:35 PM
Rage3211
Sep 19, 2017 11:46 AM
brown7373
Nov 27, 2014 07:55 PM
bspaulding
Feb 9, 2014 02:17 PM
BStone
Aug 20, 2011 06:14 AM
