hood frame replacing
has anyone replaced a hood frame? i have a 69 cutlass s that the hood frame is rusted and want replace it with a 70 frame. i know the latch is different and will need to be changed
Note, however, that the 69 and 70 top plates are the same. Since you already know about the latch, you should be able to use the compete 70 hood on a 69. Of course, you may have the problem of needing a "double hump" 69 hood and having a flat 70 hood as a donor...
70ConvCutlass
Body work
February 20th, 2011 06:37 PM
1969goatman
August 30th, 2010 07:44 PM
georgiaboy697
July 2nd, 2010 09:23 PM
