hood frame replacing
Old Dec 4, 2008 | 05:52 AM
49rebuild's Avatar
has anyone replaced a hood frame? i have a 69 cutlass s that the hood frame is rusted and want replace it with a 70 frame. i know the latch is different and will need to be changed
Old Dec 4, 2008 | 07:34 AM
If you are talking about the underside frame, it is spot welded to the top plate. Use a spot weld cutter to remove all the spot welds and separate the two. There is adhesive under the diagonals that may also need to be cut.
Note, however, that the 69 and 70 top plates are the same. Since you already know about the latch, you should be able to use the compete 70 hood on a 69. Of course, you may have the problem of needing a "double hump" 69 hood and having a flat 70 hood as a donor...
70ConvCutlass
Body work
Feb 20, 2011 06:37 PM
1969goatman
Aug 30, 2010 07:44 PM
georgiaboy697
Jul 2, 2010 09:23 PM
DJMatthews
Dec 5, 2006 01:28 PM
