Help with weak power at distributor
Old May 23, 2013 | 07:05 PM
Finn5033's Avatar
Tried to fire up the car tonight and it would fire and quit as soon as I let the key go from starting. I checked the power wire to the distributor with my test light and it was very very weak. So I ran a wire straight from the battery to the distributor and it fired right up and ran first try. I have a GM HEI distributor and have never had this issue before. It is a 70 cutlass 350. I don't think it's a ground as everything else is working fine. What else could cause this? Any help would be appreciated, thank you
Old May 23, 2013 | 08:11 PM
You can remove the alternator and have it checked at a local auto parts store. You can even have them check it on the car if you don't want to remove it.
Old May 23, 2013 | 08:25 PM
Finn5033's Avatar
Olds64, did you reply on the wrong thread?
Old May 23, 2013 | 08:29 PM
It has nothing to do with the alternator and everything to do with the wire from the ignition circuit. Trace the wire from the "Bat" terminal on your HEI cap to where ever it's coming from, you have a bad connection.
Old May 23, 2013 | 08:41 PM
rjohnson442's Avatar
Mr. Johnson
x2 on the Dist Batt Terminal. original points systems ran on less voltage make sure you have a FULL 12 volts to the distributor.
Old May 23, 2013 | 08:46 PM
Sugar Bear's Avatar
Was the wire that you ran from the battery negative or positive? If it was positive then the problem is probably not a ground.
Low primary voltage to the coil is from either a bad connection as mentioned by a previous poster or that the pink resistance wire to the primary side of the coil from when the car had a point style distributor was not upgraded. HEI distributors require full battery voltage, point type distributors use full voltage only in the cranking mode and reduced voltage in the run mode to prevent burning the points.
Old May 24, 2013 | 05:06 AM
Finn5033's Avatar
Ok that is good info, I did not know that. The car was already converted when I got it so I'm not sure what they did or if they did it correctly. The only thing I do know is before I swapped the engine out it was working. Although I do not know if it had a full 12 volts or not. The wire that is going to the distributor looks like a tan or faded orange with a white clip. I will trace this wire and see where its coming from. If the conversion was done correctly where should that wire be coming from?
Old May 24, 2013 | 06:00 AM
halfmoontrail's Avatar
Easiest w/HEI is a wire from the spade terminal in the fuse box for ignition
Old May 24, 2013 | 06:25 AM
I would recommend checking this wire with a volt meter, and letting us know what the actual voltage is.
The original points ran on 8-9 volts, but the HEI wants 11-14.
If you put a meter on it and it reads 8v, that points strongly to the likelihood that the HEI is being fed by the old resistance wire, rather than by a new wire.
Smart move.
As has been said, that pretty much rules out a bad ground (as you didn't change the ground characteristics, but then again, if the engine cranked, you must have had a good ground to run the starter, right?), and points to low input voltage.
A bad connection is less likely than the resistance wire still being active, since bad connections seldom provide "kind of enough" current, and are usually just all-or-nothing.
Ideally, your HEI wire should come from a soldered connection to the heavy pink wire from the ignition switch.
It is also possible to run it from the IGN tap on the fuse block, but that's just not as secure as a solid connection.
Old May 24, 2013 | 07:55 AM
Finn5033's Avatar
Smart move.
I plan on bringing a voltmeter home and checking the voltage that was my next move. The only thing that is weird to me is that it worked before on my old engine. Although as I stated I did never check the voltage. This may be a stupid question but is it possible that it had enough voltage to keep cranking an older worn engine but not enough to keep cranking a fresh rebuilt engine? Thanks for the help
Finn5033's Avatar
This was my next move if I can't figure out what the problem is. Thanks for the tip
Old May 24, 2013 | 08:10 AM
BILL DEMMER's Avatar
Just the facts...
bear in mind, that resistance wire will show full battery voltage to a high impedance voltmeter. the resistance wire resists the flow of current, if there is no appreciable current flow in the circuit, there is effectively no voltage dropped by the resistance wire. with the addition of a relay driven from that resistance wire, and a minimum 12-gauge wire from a switched & fused high current source, to the relay, you'll have reliable power for the hei system. of course, to complete the circuit, the relay will require ground for the coil, and a 12-gauge wire to the BAT terminal on the distributor cap, from the relay. fusing for this circuit should be 20 amps. you can accomplish this via fusible link or a standard inline fuse(slow blow fuses are better in this circuit).
bill
Old May 24, 2013 | 09:09 AM
Not that weird. I don't know why, but this is a story I've heard a number of times:
HEI worked well on resistance wire, then suddenly didn't.
I have no idea why it happens, but it does.
... is it possible that it had enough voltage to keep cranking an older worn engine but not enough to keep cranking a fresh rebuilt engine?
Not really. If something like that is going to happen, it will break up at high RPM or under high load, but not at idle.
Originally Posted by BILL DEMMER
bear in mind, that resistance wire will show full battery voltage to a high impedance voltmeter...
... IF it has no load on it, so be sure to check voltage with the HEI connected, not with the wire hanging free.
But, remember, GM never installed a fuse in the ignition circuit, whether points or HEI, so it isn't strictly necessary to do so.
Old May 24, 2013 | 09:19 AM
Finn5033's Avatar
Good to know, I was going to check it with it unplugged. I will make sure to check it while connected. Thanks I will let you know what I come up with
Old May 24, 2013 | 09:24 AM
You can tell the resistance wire by it being very stiff compared to a standard wire. I did the relay setup described above which ensures battery voltage to the distributor.
Old May 24, 2013 | 09:31 AM
Plus, it's shiny silver in color, rather than copper-colored.
Old May 24, 2013 | 09:53 AM
Troys Toy 70's Avatar
Once Olds Always Olds
Silly question, but if the resistance wire cuts the voltage when it is running, why would it not show the 12 volts with just the ignition on whether or not its plugged in?
Old May 24, 2013 | 09:55 AM
Because the HEI si still drawing current when the engine isn't running, though it does draw more when running than when not running.
Points, on the other hand, may draw no current when not running, if the points are in the open positon.
Old May 24, 2013 | 10:33 AM
sixtyfour's Avatar
Condenser??
Old May 24, 2013 | 04:32 PM
Just the facts...
that's why i included the sentence immediately following the one you quoted.
"the resistance wire resists the flow of current, if there is no appreciable current flow in the circuit, there is effectively no voltage dropped by the resistance wire." maybe i could've made that clearer, that the resistance wire would need a load to show anything other than full battery voltage when measured by a high impedance multimeter. i assumed that the OP would measure it open circuit.
the ignition circuit was connected to a fusible link protected circuit. it would be foolish not to fuse/fusible link a circuit added after the fact. it's just sensible, and best practice, when you're creating a new circuit, as my post was alluding to.
bill
Old May 24, 2013 | 06:19 PM
Your description was completely clear to someone well versed in electrical theory, but, I think, less so to the complete amateur, who doesn't even have a voltmeter at his house.
I felt it sensible to spell out your correct but complex statement.
The ignition circuit is still connected to the same fusible-link-protected circuit either way.
If you choose to add an additional fuse, that's fine.
However, I find it interesting that the only circuits in the car (as far as I can tell) that were unfused were the cranking circuit and the ignition circuit.
The cranking circuit is high-current, only used very occasionally, and controlled by a momentary switch, so I suppose they figured it was not necessary to spend the money on a 30 or 40 amp fuse for it.
The ignition circuit could easily have been fused, but was not.
My personal belief is that the designers felt that the risk of sudden loss of power, possibly from failure of a faulty fuse, rather than from a defect in the ignition system, was greater than the risk of a short, which could be corrected by turning off the ignition switch.
Regardless, they chose not to fuse this one circuit when they easily could have done so,
I would not argue against fusing this circuit, but I feel that in the interest of clarity it must be stated that it was not fused when the car was made.
Old May 25, 2013 | 03:34 AM
Yellowstatue's Avatar
If you add a fuse in the circuit, does that make you a fusilier??
Old May 25, 2013 | 10:49 AM
What!?
I don't know why I made that reply. Maybe I'm loosing my mind.
Old May 25, 2013 | 10:17 PM
Just the facts...
clearly, not.
bill
stocki26
Ninety-Eight
15
Apr 16, 2013 01:12 PM
plonka
Jan 25, 2013 10:36 PM
Blackpage
Sep 5, 2012 05:05 PM
gearheads78
Jul 2, 2011 08:12 PM
jpaulwhite
Apr 27, 2011 02:58 PM
