Those are NOT NPT thread. The inlet to the pump is a hose barb for the rubber hose. It is integral to the pump on stock style pumps and not replaceable. The outlet is an inverted flare fitting, just like the one on the carb inlet. There are no NPT fittings in either the stock fuel system or the stock brake system.
To get back to your original question, here are the dimensions, as discussed here recently.
