Help with NPT fittings measurements
Old Jun 27, 2016 | 01:11 PM
Christophe2m6's Avatar
Hi guys!
Looking for some help as I'm not used to NPT measurements.
Would like to know the NPT dimensions for both connections to my fuel pump.
1- Fuel line from carb to fuel pump Tee connection = about 0.63inches OD
2- Tee fitting connected to the fuel pump: about 0.54inches OD
What could/should be the NPT dimensions?
Thanks a lot for your help!!
Chris
Old Jun 27, 2016 | 01:27 PM
The approximate ID of the fitting is the actual size. Example a 1/4 in pipe filling has an ID of 1/4 inch.
Old Jun 28, 2016 | 07:26 AM
Those are NOT NPT thread. The inlet to the pump is a hose barb for the rubber hose. It is integral to the pump on stock style pumps and not replaceable. The outlet is an inverted flare fitting, just like the one on the carb inlet. There are no NPT fittings in either the stock fuel system or the stock brake system.
To get back to your original question, here are the dimensions, as discussed here recently.
AtomicMyke
Jun 16, 2016 03:31 PM
TylerW
Jun 6, 2014 07:22 AM
devmar07
May 14, 2010 09:23 AM
alsmith
Mar 9, 2010 09:30 PM
cornwallis
Sep 21, 2009 08:44 AM
