Help no spark at the ignition coil
Old April 15th, 2023 | 08:28 PM
Lazytoseizetheday's Avatar
So I’m trying to diagnose issue starting my
baby…. No spark coming from coil. 😞
Old April 16th, 2023 | 03:13 AM
fleming442's Avatar
Is there voltage going to it? Voltage at the points?
Old April 16th, 2023 | 04:07 AM
I moved your posts to a new thread. Hopefully you'll get more views this way. Good luck.
Old April 16th, 2023 | 05:04 AM
As fleming442 noted, check for voltage going "into" the IGN coil. You must have voltage going in before you can have voltage coming out. If you have voltage going into the IGN coil check the IGN coil itself.
Measure both the primary winding resistance and the secondary winding resistance of the IGN coil.
Take the several minutes to read this >>> Electrical advice please.
Old April 16th, 2023 | 05:05 AM
It would help if you posted what distributor/ignition type your using?
Old April 16th, 2023 | 05:13 AM
fleming442's Avatar
My 63 died one time in traffic. We pushed it to a side street. As I'm standing there scratching my head, this old dude on his porch asked if I had "power to the points". I was (still am) pretty clueless about points, so the old dude walked me through pushing the contact in and checking for arcing across the contacts. The problem was actually that the coil wire had wiggled up out of the cap. Pushed it down, and away we went.
Old April 16th, 2023 | 05:25 AM
How about telling us year, model, engine, and ignition type? Is it stock or modified? The mind reading thing still isn't working.
Old April 16th, 2023 | 05:27 AM
Old April 16th, 2023 | 05:34 AM
I assumed the OP was referring to his 1964 Olds 98 Town Sedan, wrongful on my part to assume...valid point(s) to ask.
Old April 16th, 2023 | 05:36 AM
That information isn't found anywhere in this thread, unfortunately. And of course, there is still the ***-U-ME problem.
Old April 16th, 2023 | 05:37 AM
Yes, it was the OP's 64 98. Sorry I didn't put an explanation when I moved the first 2 posts. You can blame Oldsguy. He's visiting and was bothering me this morning when I should have been doing more important things.
Old April 16th, 2023 | 05:45 AM
Uh huh...passing the buck. You blame Oldsguy & we'll blame Olds64.
Old April 16th, 2023 | 05:49 AM
OK, thanks. So stock points and igntion coil? There's a sticky.
https://classicoldsmobile.com/forums...gnition-76706/
Old April 16th, 2023 | 04:58 PM
Ok yes it’s stock I’ll send pic
But first off thank you this made my weekend
whew . Still no luck with spark , but man thank God for this forum. I’ll have to reread some of electrical advice thread . In order to check coil ( its new ) I was looking at old coil there’s a terminal still attached, looks like I pulled wire from idk 🤷🏻‍♂️
Old April 16th, 2023 | 05:01 PM
It’s wired per diagram , curious if it not grounded at distributor…
Old April 16th, 2023 | 05:17 PM
Old April 16th, 2023 | 05:29 PM
fleming442's Avatar
.....curious if a fuse blew. Got J.U. Ice?
Old April 16th, 2023 | 06:27 PM
Do you have a test meter (Digital Multimeter) to measure voltage & resistance (Ohms)? Your first order of business is to measure the voltage at the positive (+) terminal of the ignition coil. Do you have ~12V at that terminal? You must have an input voltage at the positive (+) terminal of the ignition coil. Whether your coil is new or old, you're DOA if you can't provide an input voltage at the (+) terminal.
Old April 16th, 2023 | 06:36 PM
The key needs to be in the switched ON position to read ~12V at the positive (+) terminal of the ignition coil. I didn't mention this...look at the image you posted above (Post #15) ...ignition switch to coil wire. Measure that voltage at the ignition coil.
Old April 16th, 2023 | 07:01 PM
Are you running points or an electronic module? If it's a module, it needs power.
Old April 17th, 2023 | 04:16 AM
That was my fault...I thought the OP had said it was points but I re-read and the question hasn't been answered.
You need to state whether you have points or electronic ignition.
Old April 17th, 2023 | 06:07 AM
Start with the most likely failures, not the low-probability ones. Also, once again, please answer the question: do you have points or an electronic conversion, and if the latter, which one?
Is there power at the + terminal of the coil with the key in RUN and START positions? Does the - terminal of the coil alternate between closed and open to ground with the engine cranking?
Old April 18th, 2023 | 09:13 AM
Points
Yeah she is stock …..points at distributor
Old April 18th, 2023 | 09:25 AM
Disconnect the wire at the "-" terminal on the coil. Check continuity from that wire to ground as the engine turns over. You should see open circuit when the point are on the high part of the distributor cam and continuity when the points are closed. If not, figure out why.
Old April 18th, 2023 | 10:20 AM
That is not how it's wired if it is stock. Instead of measuring continuity, pull the high voltage lead off the top of the coil to prevent starting, hook a test light to the coil negative terminal. Crank the engine with the key and see if the test light blinks on and off.
Old April 18th, 2023 | 11:48 AM
That is exactly how it is wired. The points are simply a switch to ground.
Old April 18th, 2023 | 02:45 PM
I understand how points work, show me where the fuse is for the igniton. In simplest terms yes that is a typical ignition system without those pesky items like the resistance wire and the bypass wire.
Old April 18th, 2023 | 05:53 PM
I'm not talking about the power side of the circuit. I'm a big fan of testing at the lowest level possible. The method I suggested only tests the points and the wire to the coil, period. Bad or improperly adjusted points are a high probability cause of ignition problems.
Old April 18th, 2023 | 05:59 PM
Maybe not the highest probability but if you ain't gots no juice going in you ain't gonna have no juice coming out....period.
Old April 18th, 2023 | 08:02 PM
The method I suggested after you, tests for both power and to see if the points are opening and closing.
Old April 18th, 2023 | 08:05 PM
  #31
Checked - terminal with test light
It flashes when turning over 👍🏼
Old April 18th, 2023 | 08:19 PM
  #32
Checked voltage at + terminal
12v at positive terminal w/ ignition on
Old April 18th, 2023 | 08:36 PM
  #33
Points open vs closed
So I am trying to test continuity by removing neg wire . Points look closed .
Old April 18th, 2023 | 08:38 PM
  #34
Test coil:
(1) Remove all wires from coil
(2) Measure resistance (Ohms) of primary winding in coil. Attach one DMM probe to (-) terminal on coil attach other probe to (+) coil terminal. Reading must fall below 2.0 Ohms.
(3) Measure resistance of secondary winding. All wires disconnect from coil. Place one DMM probe on coil (+) terminal and other probe inside the top (center) tower where the coil wire would be attached. Set Ohm scale to 20K. Resistance must be greater then 6K, optimally greater than 13K+ Ohms.
Old April 18th, 2023 | 08:43 PM
  #35
If the primary winding is <2.0 Ohms and the secondary winding is >10K+ Ohms the coil is OK. That will tell you the coil can produce the required voltage for spark to start the engine.
Old April 18th, 2023 | 08:57 PM
  #36
You indicated the test light flashes therefore points are opening and closing. Testing coil primary & secondary winding demonstrates if enough voltage can be delivered. This is not to say the points are not adjusted correctly or there is a different issue.
Old April 18th, 2023 | 10:24 PM
  #37
If it's flashing when turning over then you have power to the coil and the points are opening and closing. If at this point you have no spark chances are good that your coil is not working. One more test, connect the high voltage wire back up and attach a timing light to that wire and see if it flashes. If it does, then either your timing is off or your not getting fuel.
Old April 19th, 2023 | 07:01 AM
  #38
Ok going to pop hood tonight
Thank you for you guy’s response. 👍🏼
Old April 23rd, 2023 | 07:22 PM
  #39
Timing light
No light when turning over 🤦🏻‍♂️
Old April 23rd, 2023 | 08:05 PM
  #40
Checking ohms on ignition coil
With ohm meter at 2k - to+ 12.87
+ to lead runnig to distributor 19.5
Quick Reply: Help no spark at the ignition coil
