Help for a newbie
Old Aug 22, 2019 | 07:22 PM
wasjr1117's Avatar
Help for a newbie
I just inherited a 67 Cutlass convertible. I am trying to figure out exactly what I have. Is there a way to interpret the VIN to determine what engine and other details of the car?
Old Aug 22, 2019 | 07:43 PM
Post a picture/image of your VIN and your Cowl Tag - plenty of folks to assist you w/ identifying your vehicle. The Cowl Tag will provide details of original color, interior, upholstery, etc.
Below examples of VIN tag & Cowl Tag.
Old Aug 22, 2019 | 07:58 PM
Deciphering Your 1967 Oldsmobile Cowl Tag
Old Aug 23, 2019 | 12:20 PM
Welcome. Neither the VIN nor the cowl tag will tell you what engine the car came with (other than the fact that it was a six or a V8). Unlike the photo posted above, your VIN tag is on the driver side door post. All the VIN will tell you is model line, body style, model year, and assembly plant. The 1967 cowl tag will have paint, interior, build date, and some option info. Keep in mind that the cowl tag was installed by Fisher Body before the body was mated to the chassis and drivetrain and only has info that was important to Fisher, thus no engine or drivetrain info.
Old Aug 23, 2019 | 12:54 PM
Won't the protecto plate, if still with the documents, have the engine designation on it?
Old Aug 23, 2019 | 01:00 PM
That's unfortunately a big "IF", but if the P-O-P is available, it will have the engine and trans unit number, so at least you can match the trans case and one head to the VIN. Yes, the engine unit number will provide some insight into the original engine, but not complete details. It pretty much will only tell you 330 vs 400 vs 425 and HC vs LC.
Old Aug 23, 2019 | 01:56 PM
Is there a way to ......determine what engine and other details of the car?
Assuming it's equipped with a V-8, here's some information you may find useful. Do you know where to look for the engine casting number? It's right behind the water pump on a ledge - front of block.
Old Aug 23, 2019 | 02:21 PM
I'll add that unlike the widely-quoted casting number info from the Olds FAQ, the table Allan posted is actually correct and fixes much of the incorrect info in the FAQ table. The only thing that's a little confusing is the "Gen 1" and "Gen 2" designations in this table. All the motors listed on that table are considered to be second gen Olds V8s. The first gen motors are the 1949-1964 303, 324, 371, and 394 motors.
Old Aug 23, 2019 | 06:04 PM
wasjr1117's Avatar
Thanks for the info. I found the code and it is the 330 as I expected.
442noob
Aug 27, 2016 08:08 AM
BelgiumOlds
May 31, 2016 06:42 PM
brianbeez67
May 2, 2014 02:36 PM
AirborneRME
May 7, 2013 08:09 AM
Joffroi
Dec 9, 2012 07:17 AM
