HELP! for my '67 442
hi guys need some help i'm finally getting around to restoring my '67 442. first thing there is a round --looks like a vacuum canister mounted on the firewall what does this go to?? it has the climatic combustion control air cleaner on it does it hook to this?? also need some parts--a fan shroud for the 400 and a drivers side exhaust manifold for the same. i'm also going to need front end,brakes and so on. I've used opgi,and bap any other companies out there with quality parts?...any help is appreciated..thanks gary
OPGI lists a repro fan shroud. Some other parts can be found on ebay. Fusick is good for some parts. I have heard nothing but bad about BAP/Brothers so I stay away from them. I also had some trouble with seat covers and a radiator from OPGI.
The vacuum tank is not limited to AC use. Power trunks and cruise control also required the tank.
Gary, the tank info and much more can be found in the Assembly Manual available free of charge at Wild About Cars:
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
Koda, you have to create an identity on the site. Once you do that, you tell them what vehicle you want to check, and it creates your "Dashboard" where you can check repair manuals, promo material, engineering manuals, just about anything you would want, especially regarding Olds. Just go to "Factory Publications". It is, without a doubt, the most inclusive Olds Info site available.
Also deals with lesser desirable vehicles, like Mopar, Fomoco, and other trash (my opinion, anything else is a wannabe).
Ask wmachine, the resident Wildaboutcarsonline advocate!
ToronadoGuyDenver
Brakes/Hydraulic Systems
March 18th, 2007 02:52 AM
