Help me fix the front end
Old Feb 16, 2022 | 10:23 AM
Coastie's Avatar
Stock cars are too boring
Alright, so I'm gonna start off with this; I refuse to put the hood back on. Open engine bay all the way.
Now with that said, I'm losing some chrome work and it leaves the front a little lacking. Any suggestions on what I can do to make it look more appealing? I've been told to cut the front of the hood off and mount that over the radiator support cover. I've also been told to cut the hood basically to the edges and put it on, but I feel like that has its own issue.
Old Feb 16, 2022 | 10:26 AM
RandyS's Avatar
You're kidding right???
Old Feb 16, 2022 | 11:07 AM
leftlaneonly's Avatar
Steer Horns
Old Feb 16, 2022 | 11:26 AM
Coastie's Avatar
I just want some ideas
Coastie's Avatar
Originally Posted by leftlaneonly
Steer Horns
I don't think that's it, but I love the energy. Keep em coming!
Old Feb 16, 2022 | 11:39 AM
HighwayStar 442's Avatar
Steer Horns
Dying to put them on one of my Cadillac's. Since I moved back to Texas. This one is good for taking out pedestrians walking too slow, crossing the road.
Below, This maybe the way to go with your car. I can see the the scoop really standing out! Can be the start of a new look!!!!
Old Feb 16, 2022 | 11:46 AM
Loaded68W34's Avatar
Remove the hood latch mechanism and install a small aluminum keg gas tank "gasser style" in its place right above the center grill bar
Old Feb 16, 2022 | 11:54 AM
VI Cutty's Avatar
That space definitely needs to be filled...the front end looks incomplete/projectish without it. I think the suggestion of cutting down a hood is along the right track...maybe straight across at a midway point on the top plate with some metal fabricated as a round down at the back edge. That, or a fibreglass mold of the hood with mods to make it flow.
The only other thing I can think of is just some sheet metal bent to fill the space above the grill and lights, folding over the top edge...just something to smooth things out and hide the under structure.
Old Feb 16, 2022 | 11:55 AM
Coastie's Avatar
I actually have a Miller lite mini keg that I had strapped to the front for a time (used as coolant overflow), but I'd like to mount it more securely than massive hose clamps. Any suggestions that don't involve welding?
Old Feb 16, 2022 | 12:14 PM
NTXOlds's Avatar
This is the gasser, right?
I would personally cut a hole in the hood and put the hood back on, but I know you are opposed to that.
A quick google search found some images you might like.
I think that this car has a "partial hood" covering the radiator cover which is probably like what you were describing. I like this a lot since it completes the visual of the front end but leave the engine exposed.
Looking at 67 Gassers, I like the front end of the top one of these more than the bottom one. Both are pretty cool, though.
Good luck!
Old Feb 16, 2022 | 12:30 PM
Coastie's Avatar
Good luck!
I'll look into cutting my hood to do the first pic..I'm also not running a front bumper, so that probably won't help
Old Feb 16, 2022 | 12:34 PM
Goldiewilson4mayor's Avatar
Goldiewilson4mayor
I had same dilemma once upon a time , I cut one hood in a huge u shape , another I cut just past fan shroud, and yet another I went right part the the steering res. I ending using the one I cust just past the fan shroud the most as it was never in the way , it completed the front of the vehicle
Old Feb 16, 2022 | 12:37 PM
Coastie's Avatar
Any chance you got a pic? How did you attach it to the car so it would be stable?
Old Feb 16, 2022 | 12:42 PM
gs72's Avatar
72Cutlass S
Put one of these on the front end.
Old Feb 16, 2022 | 03:39 PM
fleming442's Avatar
Definitely lose the center support and latch. I think the stone guard should go, too, if the bumper is staying off.
How about painting the firewall a contrasting color like an old rod- a checker board or bright color like yellow or red...
​​​Definitely the Moon tank! Tube bumper or tow bar attachment?
Old Feb 16, 2022 | 03:44 PM
Coastie's Avatar
C
​​​​​​cut the hood. Just need to line it up and figure out a way to secure it. I'm thinking 2 bolts in the back corners, sandwiching the hood down.
Old Feb 16, 2022 | 04:51 PM
Goldiewilson4mayor
Originally Posted by Coastie
C
I used a bolt through the fender in to the hood on the back with a hole drilled into the bolt for a clevis pin and use the hood latch on the front. The good thing is the bolts act like a hinge and the hood pivots for access to the rad cap or battery.
olds 307 and 403
May 3, 2018 01:12 PM
cdrod
Body work
Jun 30, 2014 10:38 AM
barnfind
Dec 11, 2013 01:16 PM
72cutlassdog
Feb 8, 2013 09:19 AM
archeryshooter
Sep 2, 2011 07:15 PM
