Help identifying an intake?
Old Nov 28, 2021 | 02:13 PM
Coastie's Avatar
Stock cars are too boring
For the life of me, I can't find the intake anywhere. Any links/ideas?
Old Nov 28, 2021 | 02:22 PM
BillK's Avatar
Almost looks like a Two 4BBL inline manifold that somebody has modified. Cant tell what seems to be bolted to the back carburetor pad.
I have a 2x4bbl Offy intake at the shop. I will take a look at it Monday morning.
Old Nov 28, 2021 | 02:24 PM
TimMC's Avatar
offy 360 dual quad with cross ram adapters?????
https://www.speedwaymotors.com/Dual-...ge,400773.html
Old Nov 28, 2021 | 03:21 PM
hurst68olds's Avatar
offenhauser #5497 universal cross ram adapters on a 455 dual quad intake #5589
Old Nov 28, 2021 | 03:35 PM
BillK's Avatar
There you go It was hard to tell by the picture angle what was bolted to the back flange.
Old Nov 28, 2021 | 04:09 PM
HX3's Avatar
HX3
Yeah, that's the intake on my '67 442. My only suggestion is to make your own bell crank throttle linkage if you plan to go this route. I purchased the Offy linkage but once set-up, it was too flimsy for my liking. I also installed a Lokar gas pedal for a '64-'67 Ch****le with a cable pull setup.
67 Olds 442 Gasser
Old Nov 28, 2021 | 04:23 PM
Wow It looks badass! How does it work?
Old Nov 28, 2021 | 06:08 PM
Indeed, and I want to know also what was done to the engine to make it want so much gas; must be ungodly.
Old Nov 28, 2021 | 07:00 PM
70W-32's Avatar
On Ebay now.
https://www.ebay.com/itm/15443979768...gAAOSwUlxaMwUe
Old Nov 28, 2021 | 07:01 PM
70W-32's Avatar
On facebook
https://www.facebook.com/marketplace...8-5fcf660be3d3
Old Nov 28, 2021 | 07:05 PM
70W-32's Avatar
Or this on Facebook
https://www.facebook.com/marketplace...e-6ee5701daed0
Old Nov 28, 2021 | 07:27 PM
70W-32's Avatar
Craigslist Metro Detroit
https://detroit.craigslist.org/okl/p...396133182.html
Old Dec 6, 2021 | 06:51 AM
Coastie's Avatar
Alright, so I bought this one (should be shipped today). I'm thinking of just keeping the single carb set up for now, but I'd like a bit more height. Any suggestions for spacers between the intake can adapter?
Old Dec 6, 2021 | 08:23 AM
fleming442's Avatar
I'd have to see a side view, but it looks like a carb spacer would be the easiest, albeit funny looking IMO. You're probably looking at a custom piece for a runner/collector extension or a plenum spacer.
Old Dec 6, 2021 | 11:25 AM
Coastie's Avatar
I'd rather avoid a carb spacer because it's already going to look hot enough with just a single carb.
Someone did suggest these, but I'm not sure if they'd fit, or if the application would work.
https://www.ebay.com/itm/23422908136...d&toolid=10050
Old Dec 6, 2021 | 01:36 PM
young olds's Avatar
Old Dec 6, 2021 | 04:48 PM
fleming442's Avatar
Well, slap me on the @$$ and call me Sally. I never knew those existed! They look close enough to make work.
Old Dec 6, 2021 | 07:41 PM
truckman5000's Avatar
W30
I've always wondered this, since the dukes of hazard car....I've seen this set up 3 times.
Performance good? Or mainly looks? Either way cool to me. Thanks
Old Dec 8, 2021 | 05:16 AM
Coastie's Avatar
I just realized I don't know the model of the intake I got. Anyone got an idea so I can find gaskets and bolts for the intake and top part?
Old Dec 8, 2021 | 05:52 AM
BillK's Avatar
Chase,
If the ports are the same as the low rise Offy manifold I have here then there should be a number on the underside of it. I would think that the stock Olds manifold bolts should be the correct length and you will probably just have to measure the top part to see what you need there. The Fel Pro 1356 gaskets will probably work but it is also going to depend on what heads you are using. I would wait until you had the manifold and measure the ports before you order anything.
Old Dec 8, 2021 | 06:02 AM
fleming442's Avatar
Make sure you dry fit it between the heads, check the angle, and bolt hole alignment
Old Dec 8, 2021 | 06:32 AM
BillK's Avatar
Definitely true. The one I have is terrible but I milled .035 off the decks on the block so I was expecting it But it is very uneven from front to back too. You have to check everything.
Old Dec 8, 2021 | 06:56 AM
fleming442's Avatar
Yep, I had a Performer that wouldn't seal for crap. The angle to the head surface was off 0075 (015 at one side, top of flange).
Old Dec 8, 2021 | 08:41 AM
Coastie's Avatar
Any ideas what I should expect for performance?
Old Dec 8, 2021 | 09:19 AM
BillK's Avatar
I know you dont want to hear it but I would probably say not good at all unless the engine is very highly modified and a lot of cubic inches. On a mild engine a dual plane performer would be much better.
But it will look neat
Old Dec 8, 2021 | 09:23 AM
Coastie's Avatar
It's a mild 455 punched to a 468. Just don't want it to be an absolute PoS on the street.
Old Dec 8, 2021 | 10:53 AM
edzolz's Avatar
I have never understood why some folks think multiple carbs will perform better than a well tuned single carb set up for the correct air/fuel ratio. They look good but perform?
Old Dec 8, 2021 | 02:37 PM
gs72's Avatar
72Cutlass S
I had to bust this one out again. Lol
Old Dec 8, 2021 | 04:44 PM
fleming442's Avatar
That's impressive!
w30442
Jun 5, 2023 01:17 PM
380 Racer
Sep 29, 2022 07:38 AM
Mikedeneen21
Aug 6, 2021 04:34 PM
zeeke
Aug 28, 2017 06:17 PM
1966g10
Nov 18, 2013 10:35 AM
