Help with the Body Tag & Engine number
Old Oct 25, 2010 | 06:47 PM
71 Rookie's Avatar
71 Rookie
Hello All,
The Body Tag
Body by Fisher
ST 71 34267LAN336377 BDY
TR 987 75 A PNT
03C
GENERAL MOTORS CORPORATION
What can you tell from this Tag? Where can I look this up?
I also got the Engine #1280683 off of the Oil Filler Neck. What does that tell me? Where can I look this up?
Thanks,
CT
Old Oct 25, 2010 | 08:06 PM
stevengerard's Avatar
71 - 1971
3 - Oldsmobile
42 - Cutlass Supreme (thanks Joe)
67 - convertible
LAN Lansing assembly plant
336377 body number - not the VIN number and shouldn't match the VIN either it was the 236377 body that went down the assembly line
TR 987 Interior code - I think this is white/pearl in 71 notch bench (thanks Randy)
75 - paint color - matador red
A - top color - White convertible top
03C is the week the car was built
03 - third month of 1971, March
C third week of the month
the number on the oil fill tube is the engine number (thanks Kurt)
Old Oct 26, 2010 | 06:28 AM
wmachine's Avatar
Trying to remember member
Originally Posted by stevengerard
71 - 1971
the number on the oil fill tube should match the engine number
? That *is* the engine unit number. There is really nowhere to match that number to.
Old Oct 26, 2010 | 07:28 AM
rcorrigan5's Avatar
Randy C.
TR 987 indicates white interior with a notch back bench seat in front.
Randy C.
Old Oct 26, 2010 | 08:39 AM
42 - Cutlass
Actually, 42-series is Cutlass Supreme, not just Cutlass.
Old Oct 26, 2010 | 08:43 AM
Kurt, that's what I meant but I was wondering if that number matched something on the block. If not then there is no way of really telling if that engine oil tube is original to the car then is there? I just noticed this the other day, that the number stamped on my oil tube was not a VIN derivative and did not seem to come close to matching any of my other numbers - that is then normal correct?
Old Oct 26, 2010 | 05:28 PM
wmachine's Avatar
Quite correct. That is the engine sequence unit number. Matches nothing else except it was "in the system" somewhere. Through '67, the engine unit number was on the front end of the passenger side head. But in those years the number was also on the Protec-O-Plate. Conceivably could confirm that an engine is original, but like the oil fill tube, the head could be put on another engine. Not great places to put engine numbers is it?
Old Oct 26, 2010 | 08:12 PM
rcorrigan5's Avatar
Randy C.
Another thing about the number on the oil fill tube: The first number indicates the model year. If the first number is "1" and you have a '71, then at least the oil fill tube matches your model year.
Randy C.
knoggin
Apr 17, 2014 01:48 PM
peganit
Jan 28, 2013 01:33 PM
Alg
Jan 1, 2013 05:04 PM
arodenhiser
Mar 10, 2011 06:05 PM
roadster-rob
Mar 9, 2008 10:24 PM
