Help
Old May 28, 2014 | 07:30 PM
albert8b's Avatar
Help
I am new to this site and I am trying to figure out how to put a photo of my car with my comments or posts. Your help is greatly appreciated.
Albert
Old May 28, 2014 | 07:53 PM
Macadoo's Avatar
I use an outside host, photobucket.com. It's free. Once you upload to that site, click on the photo. To the right you'll see "links to share this photo". Click on the IMG choice and that will copy the correct code. Then in this forum click the icon with the mountains (insert image) and copy that code into the box. Sounds complicated but it's not. Good luck and welcome to CO
Old May 29, 2014 | 06:58 AM
Tedd Thompson's Avatar
There is a sticky posted on the newbie site that will walk you through it. If that doesn't work give a hollar, The most often problem that occurs is that your file (picture) is to large and needs to be reduced to under 100 kb...Tedd
Old May 29, 2014 | 07:02 AM
Read this post:
https://classicoldsmobile.com/forums...-pictures.html
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
