Headlight Housing
Old May 29th, 2011 | 10:34 PM
jdana24's Avatar
1968 Olds Cutlass S
Headlight Housing
Does the bumper need to be removed before I can remove the headlight housing? Or do I take off the radiator top support?
Old May 30th, 2011 | 12:01 AM
1968Cutlassfallbrook's Avatar
Yes you'll need to remove the bumper to take the headlight housings off or you might be able to do it if you drop it down a bit. Be careful as the 68 housings are very easy to break. also be careful around the grill if you have one as the tabs break off easily.
jensenracing77
September 12th, 2010 02:15 PM
import extermination
Body work
February 4th, 2010 06:34 PM
70Post
August 13th, 2009 11:31 AM
nickthetrader
January 19th, 2009 10:14 PM
reallife
May 2nd, 2008 07:21 PM
