Headlight Housing
Old May 29, 2011 | 09:34 PM
jdana24's Avatar
1968 Olds Cutlass S
Headlight Housing
Does the bumper need to be removed before I can remove the headlight housing? Or do I take off the radiator top support?
Old May 29, 2011 | 11:01 PM
1968Cutlassfallbrook's Avatar
Yes you'll need to remove the bumper to take the headlight housings off or you might be able to do it if you drop it down a bit. Be careful as the 68 housings are very easy to break. also be careful around the grill if you have one as the tabs break off easily.
jensenracing77
Sep 12, 2010 01:15 PM
import extermination
Body work
Feb 4, 2010 05:34 PM
70Post
Aug 13, 2009 10:31 AM
nickthetrader
Jan 19, 2009 09:14 PM
reallife
May 2, 2008 06:21 PM
