The hassles of bringing a fanatic of an orphan car company.
The bronze distributor gear in my car is at least 2 years old, and I have several high mileage road trips planned for this summer. I figured I’d rather replace it in the comfort of my garage than along side the road 10 miles northeast of nowhere.
I spent 20 minutes on the phone with summit trying to find the part number I needed. Clue number one that I should have expected trouble: when I told the guy 3 times I had an Oldsmobile, followed by the “what is that” silence that always follows. I didn’t know what the diameter of the Holley distributor shaft was, but I figured since he had access to the catalogs it wouldn’t be difficult to figure out.
Clue #2: the guy kept telling me that GM uses a .500 shaft, and he wasn’t sure what Oldsmobile used. Obviously, in his mind, GM means “Chevy”. I informed him numerous times that Oldsmobile was a division of GM, he either didn’t believe me or hear me.
Clue #3: I told him numerous times it didn’t matter what the factory shaft diameter was (Chevy, Olds, or GM) since the car didn’t have a factory distributor. I needed to know what shaft diameter Holley used.
In the time I spent on the phone trying to explain and figure all of this out, I could have run out to the garage and pulled the distributor out and measured. Other option: call Mark!(CutlassEFI). He had the answer, and I didn’t have to listen to the silly “your call is important to us” hold music.
Just in case anyone else needs the number, it’s Comp Cams-442. That should be a pretty easy number for an Olds guy to remember!
Thanks Mark!
Thanks Mark!
15 years ago people thought my 87 442 was a Monte Carlo. (the 442s appearance was completely stock)
10 years ago I was asked if the 69 was a Nova. (she still has her factory name and manufacturer identifiers)
Currently whenever I am putting gas an admirer may walk over and compliment her, rough as she is. Every now and then the what is she comment comes up. When I tell you the answer often goes over with a thud. Both the name Cutlass and Oldsmobile, and we are talking adults to middle aged men. Shocking for me a 55 year old that remembers when Cutlasses were a dime a dozen. Often you can see the fact that the name has zero resonance with them, but because the essence of the meeting was complimentary it just falls flat. I will throw in the yeah the oldies are great cars etc bit, to try and end it on a less awkward note.
Great advice! BOP makes the most durable gear for difficult situations. They list both the 0.491 and 0.500" bores.
Go to https://www.bopengineering.com/olds_v8.shtml and look at the seventh item down.
At least you didn't install it yet! I went through all this about 4 years ago. C19 screwed up a LOT of stuff. Actually, had a brass gear leave me on the side of highway after a friend's funeral. It started popping and missing, then just died. I have probably 15k miles on the BOP gear with zero issues, and it shows no visible wear.
