Has any removed the complete A/C unit from the Engine Compartment
I am working on my 70 Olds Cutlass cleaning up the engine compartment. I want to remove the entire A/C unit it one piece. It was supposedly converted to R134 and worked well before I started working on the front of the car. Thus, the reason I do not want to crack it open. I already have the core support off the car, the a/c coil that was in the core support is being supported by a wooded frame sitting on the frame horns. The compressor would be simple enough to remove. That brings us to the Evaperator box on the firewall, it looks like I can just unbolt the whole evaperator box and remove the coil, the compressor, and the Evaperator box all at one time.( with a little help of course)
Has anyone done this? or is there anything I should be aware of?
I did it on a 72 Cutlass parts car also. The radiator and engine were already out and the condensor mounts were broken so I took the screws/nuts out on the firewall and the compressor was already off the engine, so I just unhooked all the wires and took the whole mess out of the car.
chevyking
May 31, 2018 09:45 AM
dallasite21
Jun 19, 2010 07:42 PM
