Guys wish me luck on my purchase!!
Going to pick up a 67 convertible tomorrow with a doner cutlass conv, almost sight unseen except a few pictures and a G on the block!! Could not pass it up.............will post pics this weekend!!
That depends on what you are happy with? Heads get swapped so it does not for sure mean the engine is a 71 455. It could be newer or older or a 400 or 425 or even a small block. You need to see if there is an F on the block where water pump mounts and that will determine if it is a 455. 1971 was the 1st year for lower compression pistons and hardened valve seats. Still a nice engine for a street car.
I'm not a 455 expert, but, I think all 455's had "F" or "Fa" blocks.
Early 455's were "F" and later were"Fa".
If you ARE talking about a "G" block, correct '67 block should be an "E" block.
Although "G" block is not correct for '67, it still has value to the '68-'69 guys.
You might be able to work a trade with someone for an "E" block.
BIGJERR
February 20th, 2011 02:23 PM
jensenracing77
March 23rd, 2010 09:19 AM
Kidcutty
Suspension & Handling
March 5th, 2010 08:50 AM
