Gear Ratio Advice For Big Block Cutlass
Good Afternoon. I would like to get some advice about the right gear ratio to use on my big block cutlass. I am going to have my rear end rebuilt and want to select wisely. My current set up is a fairly stock 455 with TH400 tranny and a 12 bolt chevy rear end. Currently has open rear end with 3.73 gears. I have 20'' wheels on the back with 275/40/20 tires so im about 29'' in total diameter. With that being said I plan to put in a posi rear end but I am struggling with the gear ratio. I dont like the way my 3.73's rife on the highway, but I still want to be able to burn some rubber in the city if so desired. What are your opinions of the 3.31 vs. the 3.55 gears for my setup?
nj_cutlass72
November 20th, 2019 09:11 PM
HonestDave
Drivetrain/Differentials
May 30th, 2013 12:57 PM
