Gear ratio
Old Mar 26, 2014 | 12:39 PM
rhaberm's Avatar
Gear ratio
What gear ratio could a 69 Cutlass s with 350 2bbl 2 speed trans have?
Thank you,
Bob
Old Mar 26, 2014 | 01:21 PM
Assuming it was a US car and had the O-Type 12 bolt rear:
O-Type 12 bolt ratios are listed below. Obviously not all of these were offered with a 350-2bbl engine. In my experience, 2.56 was the most common ratio on the rears that I have seen.
2.56
2.78
3.08
3.23
3.42
3.91
(dealer installed)
4.33
4.66
5.00
Old Mar 26, 2014 | 02:09 PM
oldsmobiledave's Avatar
Fyi
You are most likely to have 2.56 2.78 or 3.08s.
Old Mar 26, 2014 | 02:20 PM
BlackGold's Avatar
For what it's worth, the standard rear end in a 1970 Cutlass with 350 2 bbl and AT was 2.56. (All the others were available as options.) I would assume it was the same in 1969, though maybe with the 2-speed automatic they made 2.78 standard. You could look it up at WildAboutCars.
All of which is irrelevant. The only way to know what gears you've got is to test or inspect it yourself. Things get changed over the years.
Old Mar 26, 2014 | 04:11 PM
Qwik71442's Avatar
Full-time Taxpayer
Yup, these are the most common I've come across...
442 Guatemala
Jan 15, 2010 10:43 AM
squirell
Jul 7, 2009 09:01 AM
Maverick
Drivetrain/Differentials
Feb 23, 2008 02:27 AM
jeffs 89 cutlass salon
Aug 21, 2007 07:57 PM
442 Guatemala
Jun 11, 2007 10:19 AM
