Gauge range for oil and water temp
Old August 20th, 2017 | 02:34 AM
73aussie455's Avatar
Acceleratii maxim rapidus
Arrow Gauge range for oil and water temp
I'm about to put short sweep electric VDO volts, oil and temp gauges in the 88.
Question for discussion is what range should the gauges be?
Looking at between 100 - 220F for the water temp and 0 - 80psi on the oil.
I recon the oil range will be okay but I'm only going to be driving her in the summer and it gets between 96 to 104F (36 - 40C) consistently for weeks on end during the hottest part of the year here.
My Delta is optioned code L74 455ci 800cfm QJet, code M40 TH400, code Y72 H/D radiator with bigger trans cooler inside. Car has code C60 ice cold factory A/C and code C49 63A alternator.
Should I go for a range from 100 - 250F on the temp and does anyone know at what temp the idiot light comes on?
Cheers and thanks for looking.
Old August 20th, 2017 | 02:59 AM
rustyroger's Avatar
'87 Delta 88 Royale
Yes, go for the 100-250f (or 50-120c), it will let you know when to give up if you're nursing it home with an overheating issue, and you will know if the thermostat is working properly.
9-16v on the voltmeter too.
Roger.
Oldssupreme
November 10th, 2016 04:22 PM
tdhill01
September 15th, 2016 05:01 PM
nisszx
January 23rd, 2016 09:55 AM
Emreozd
February 19th, 2012 07:27 AM
ent72olds
June 22nd, 2009 08:57 PM
