Fuel return line
Old Oct 10, 2020 | 08:19 PM
kevdog442's Avatar
Member
Fuel return line
Can a return line be all rubber fuel line or does it have to be steel? 69 cutlass.
Old Oct 11, 2020 | 12:09 AM
dragline's Avatar
I'd recommend stainless steel with todays fuels. You may have to use rubber for certain junctions and connections but it should be kept to a minimum. Rubber deteriorates over time and you would need a lot of clamps to keep it from whipping during normal driving.
Old Oct 11, 2020 | 05:45 AM
kevdog442's Avatar
Member
Ok thanks, was just thinking it’d be easier to install and since it’s already rubber on both ends, why not the whole way. Also being a convertible, I could run it in the frame.
Old Oct 11, 2020 | 06:26 AM
Rubber deteriorates over time and is more easily damaged by stones kicked up from the tires. The short sections used from the factory are the minimum needed to accommodate assembly and engine motion.
71cutlass350
Mar 27, 2018 09:21 PM
Oldssupreme
Jan 19, 2016 05:17 PM
TwoCalibers
Nov 29, 2014 11:51 AM
olds408
May 4, 2014 02:19 AM
Eddie Hansen
Apr 17, 2010 12:01 PM
