Fuel return line
I'd recommend stainless steel with todays fuels. You may have to use rubber for certain junctions and connections but it should be kept to a minimum. Rubber deteriorates over time and you would need a lot of clamps to keep it from whipping during normal driving.
Rubber deteriorates over time and is more easily damaged by stones kicked up from the tires. The short sections used from the factory are the minimum needed to accommodate assembly and engine motion.
