Fuel pump, painted or not?
I just seen in the 1970 engine assembly manual that the fuel pump is painted but not the pump inlet nipple. Am I looking at it correct? I didn't think the fuel pump was painted.
They generally have overspray on them but are not intentionally painted.
Remember, the guys doing the painting were not trying to emulate Michelangelo, just trying to lay some paint on the block in 30 seconds.
This video gives you a good idea of how they put these things together. You will see painting between 4:34 and 4:41.
Heck, even the oil filter and adapter got painted too. Makes you wonder why they just didn't invent 'clear' high temp engine paint earlier..... I did notice there was a shield installed around the distributor when the engine was painted though.
BTW, did you notice that at 2:58 the assembly worker stuffed an engine spec sheet on top of a bearing, and at 3:41 the inspector punched the sheet for something else?
All that GM really cared about was that the motor look pretty good in the showroom. After that - Hey, cars rust.
Anyone who's ever cleaned off an original engine and noticed where the paint was (and wasn't) knows that thoroughness was not expected.
I have always seen the fuel pump unpainted, and the oil filter housing painted. Regarding worrying about correctness,...if you are in an assembly mode and crave a factory fresh look, there is no better time to do it right. It takes a lot more self discipline and often more funds to recreate a car in its original state. Good luck with your restoration.
oldspackrat
January 20th, 2014 05:13 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
