Front Discs & SS1's - '66 4-4-2
Old January 21st, 2019 | 05:36 AM
F-85 4-4-2's Avatar
I'm going to put front disc brakes and (repro) SS1's on a '66 4-4-2 that I'm doing for my son. Wheel size doesn't need to be the correct 14x6; thinking 15x7? Please give me some guidance, as well as sources for the disc brake conversion kit and for the SS1's. Thanks.
Old January 21st, 2019 | 08:53 AM
Any repro SSIs you buy today should clear factory 10.75" disc brakes, despite what the disc brake vendors say.
Old January 21st, 2019 | 10:06 AM
66-3X2 442's Avatar
I put the The Right Stuff front disc conversion on my 66. I used 14x7 repo SS1's and had to grind the caliper for clearance. The aftermarket calipers from them are made larger for some reason and will not clear 14x7 SS1's. There's not a clearance problem using the OEM disc brakes with 14x7 SS1's. There's also not a problem using 15x7 on the aftermarket disc brakes,been there done that.
Old January 21st, 2019 | 10:51 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I did the factory conversion on my 68 off a 72 CS in 86. I had 73 SS3s on it when I did this.
I didn't notice a large improvement over the drums. Should have left it alone. But I didn't install the OEM disc bias valve. Y&S then didn't know I needed it. Simply used the OEM drum distribution block straight of the disc brake master cylinder.
The car will lock up all 4, front first, with zero drama...just as the drums did. Same pedal feel.
Would I feel a significant difference with the bias valve? Who knows. I'm leaving it alone except I think its time to replace the original booster with a nice new cad plated unit. The bladder has to be hard after 50 years.
IMO if you want a significant improvement you need to go 4 wheel disc with aftermarket larger everything. Then it will stop like a modern Challenger. Those big Brembos are awesome! Glue your face to the windshield!
Secondly, consider better drum brake shoe material. If it exists, pretty sure it does? The drums will respond very well unless you're on a road course. Same thing for OEM Disc. Hi-end brake material makes a difference when paired with that manufacturer's rotors which are generally slotted or drilled and not smelted from scrap tin like the white box crap is.
Old January 21st, 2019 | 11:38 AM
F-85 4-4-2's Avatar
Thanks. I expect to use 15x7's so they still look the part, but improve drivability and stopping with the larger contact patch.
Old January 21st, 2019 | 09:07 PM
Gerald Nickels's Avatar
Look on EBAY they have 4 SS 1 for $600 a great deal at that price w/caps.
Gerald
Mocephus
October 1st, 2021 10:45 AM
coppertopgmc
Brakes/Hydraulic Systems
April 26th, 2019 09:41 PM
akins2000
March 18th, 2015 08:50 PM
Convertcrazed
December 15th, 2014 12:22 PM
sleeton
November 5th, 2009 02:58 PM
