Favorite hand cleaner?
So what is your favorite hand cleaner for removing oil and grease and other automotive derived 'nasties'? And why?
Mine is "Goop". I remember my dad using it over 30 years ago. The best part is that it dissolves the grunge as if it was Gunk or other petroleum based solvent. No hard scrubbing is required. Then wash off with water or just wipe off with a paper towel to go waterless!
After so many years it still works great. I had some old stuff that had liquified, but still worked fine. Yesterday I had to use this stuff as an all over body wash. I came out squeaky clean afterwards!
www.goophandcleaner.com
(Available at Harbor Freight tools and may be one of the few American-made things in there!)
Gojo Orange with pumice. Doesn't freeze up on me (well, not too much) in the garage either. You can also get it in a squeeze tube for convenience, like when you get grease on your teeth and need something to brush them
Plus the wife doesn't complain about the smell of orange. She did used to complain about the smell of my old cleaner. The original gojo was a lot like 'Goop' and left an after smell that reminded you of what you'd been working on. It also used to drip in hot weather and made a mess on the garage floor where is was wall mounted. Oh well. Bottom line is as long as you have something that works, and you like it - who cares?
All the ones I use tend to turn to liquid. One of the things I use a lot is is latex gloves. Yes they will tear easily but cleanup is easy.
Hear is an easy one. "Only one way to get these hand clean mister". An the product is _________. This one is just too easy.
Rob, you do come up with some unusual topics. Keep them coming.
Don't like working with the Mechanix gloves either because I don't 'feel' the stuff I'm working on.
BTW what is the answer to your Q? I never heard that line. Might have swallowed some hooks and reeling in some lunkers, but that's a new one on me. Is it local?
I am just glad that I can get myself clean at the end of a dirty day.
Forget the latex gloves - try nitrile. Latex disintegrates at the first hint of a petroleum product. Nitrile ones often stay together to see the next days job. Much stronger too. I use them most the time. Yesterday I coulda used a nitrile body stocking...
Hee Hee, if you wore a nitrile body stocking in the 100° heat, you probably wouldn't have needed a shower. Ummm yes you would, a cold one
Having half a car torn to pieces makes me think up stuff like this...
Dishwashing liquids do a fine job removing grease and grime from hands but repeated useage also removes oils from the skin.
Pumices work great if there is running water to rinse off the residue.
I use Joe's Hand Cleaner. Cuts the grime well and finishes with a rag or paper towel. Smells good too.
I too suffer from the "wet hands" when using nitrile gloves
I didn't think it would come off. The instructions say not to get it on you at all or you'll be wearing it for at least a couple of weeks. So, bleach actually works? I would have thought you'd have better success with sandpaper.
Before that I tried gas, paint thinner, sand paper (BAD mistake b/c any chemicals use afterwards sting just a wee bit), etc.
Kresto is good stuff. It's more like a paste and has ground up walnut shells for the abrasive. Best thing it doesn't stink like Goop or similar product. The smell of Goop, Gojo or Dep will sometimes nauseate me.
Me too, but I prefer that over embedded grime and damage that cleaners and petroleum products do to the skin. At the end of a job, my hands are often the cleanest part of me. It is also nice to be able to open the door to go in without sliming it...
They are right...
Goop does not require water. Wipe off with paper towel and you're done. I prefer to rinse though and wash again with regular soap.
I have never had an issue with it being runny, but of course it is only stored and used in the house, away from the heat. Heck, even I start to melt when it is 105 outside.
Lots of great ideas here - I like the tomato one!
oldsdroptop
June 18th, 2009 06:17 PM
