Fan too big?
Old Sep 14, 2015 | 04:43 PM
kevdog442's Avatar
Member
Fan too big?
I would like to replace the stock 4 blade fan on my 68 Cutlass (with a 455) with a 7 blade clutch fan. It seems to fit in the shroud ok but rubs on the bottom of the shroud. Is a 19" fan too big? I think it's the same fan that was on the 455 originally but was in a big car. Motor mounts are only a couple years old. Pretty sure I didn't move the frame mounts when I took out the 350 and put in the 455.
Old Sep 14, 2015 | 05:39 PM
Indy_68_S's Avatar
IIRC, the '68 shroud is a bit smaller than following years. 19" sounds big. I think the original fan was 18"-ish.
I just measured my original shroud & its ~19.5" side-side. Not much room for error with a 19" fan.
Also, if your motor mounts are old, the engine may be sitting a little lower.
Old Sep 14, 2015 | 05:46 PM
toymobile's Avatar
I have a 7 blade 17in fan listed in parts for sale, Could you use that instead of trying to move the shroud??
Let me know if I can help.
Johnny
Old Sep 14, 2015 | 06:31 PM
kevdog442's Avatar
Member
Johnny
Thanks but just thought I would try it since I had it laying around. Just curious why it wasn't centered in the shroud.
Old Sep 15, 2015 | 03:24 PM
BlackGold's Avatar
Originally Posted by kevdog442
.... 68 Cutlass (with a 455) ....
Your motor mounts might be new, but are they the correct mounts matched to the frame mounts on the car? 1968 in particular is a problem child, as the parts houses have the wrong info in their catalogs.
Search for a thread on motor mounts. This has been beaten to death. Once you know you do or don't have the right mounts you can decide on a course of action.
Old Sep 15, 2015 | 05:21 PM
kevdog442's Avatar
Member
350 frame and motor mounts but they are probably Autozone so......
EightballZ
Aug 24, 2015 04:56 AM
RSmith8
Nov 1, 2013 02:22 PM
snowballs442
Dec 16, 2010 03:07 AM
agtw31
Jul 20, 2009 09:58 AM
69cutlassgirl
May 24, 2006 10:07 PM
