Fan spacer..
Old June 27th, 2024 | 03:21 PM
Tancuda's Avatar
Fan spacer..
Hi all,
working on the 71 442, and that car came with no shround and I believe a 4 blade fan, but right now as a 6 blade and a fan clutch,
my question is what would be the stock dimension (or ideal) between the front of the clutch and the rad ?
Old June 27th, 2024 | 05:03 PM
The fan placement needs to center the fan in the shroud opening, half in and half out.
Old June 27th, 2024 | 06:30 PM
Tancuda's Avatar
Ok thanks, but for now I did remove the shroud that came from a chevelle and the fan was not centered at all, was about 1 inch in the shroud, and so ugly !!
Will try it like this to see if the temp is not worse.
Thanks old cutlass
Old June 27th, 2024 | 07:31 PM
A clutch fan works best with the shroud, with no shroud I would run it 1 1/2 away from the radiator.
Old June 28th, 2024 | 05:46 AM
Tancuda's Avatar
Good to know thanks
Old June 28th, 2024 | 07:05 AM
Run to Rund's Avatar
I have a collection of spacers, different thicknesses. Let me know if you need one. I might have to find them, lol.
Old June 28th, 2024 | 08:25 AM
Tancuda's Avatar
Thanks for the offer, I will machine one to have about 1 - 1½" gap to the rad to make test and will see after. I will need about 1¼" spacer to get the correct clearance.
Are your spacers factory stock or custom ?
Thanks again
Old June 28th, 2024 | 10:49 AM
iirc they are all factory parts. I did a brief search but summer is not the best time to do an in-depth search in a Vegas attic.
Old June 29th, 2024 | 09:06 AM
Tancuda's Avatar
Don't get too hot for now. I'm doing test and if I need something stock I'll contact you.
oldsrock
April 25th, 2020 05:38 AM
jpc647
December 16th, 2016 06:21 AM
costpenn
November 12th, 2015 09:07 PM
76olds
April 25th, 2014 04:13 PM
ED50469
September 12th, 2013 08:45 PM
Quick Reply: Fan spacer..
