Fan Shroud Info Needed
Old Aug 20, 2011 | 10:51 PM
jag1886's Avatar
I have seen in photos of other peoples cars 64-67 style, a nice plastic/fiberglass fan shroud that looks like it would work way better than the metal ring that is on my car. I've seen it in several different photos so I'm guessing it's some aftermarket piece or maybe people are converting a shroud from some other car. Anyone have a clue as to the origin of these shrouds I'm seeing??
Old Aug 20, 2011 | 11:40 PM
chequenman's Avatar
Ya gotta tell us what kind of car you want this Shroud to be used on??????
Old Aug 21, 2011 | 06:23 AM
jag1886's Avatar
64-67 Cutlass down flow radiator.
Old Aug 21, 2011 | 06:47 AM
Chesrown 67 OAI's Avatar
Shrouds came mostly on A/C cars in that period. Non-A/C "A"- body cars came without a fan shroud? My 67 factory W30 car didnt come with a shroud. I got one from a Cutass that had a 330 with A/C!
Old Aug 21, 2011 | 08:26 AM
Warhead's Avatar
The plastic shroud was available on the A/C equipped 442's made in Lansing only. California cars were not made with them.
This guy has a reproduction shroud available, along with a 65 only web site.
http://www.442bro.com/
Go to the bottom left in FOR SALE. It's in there.
I've been looking for a metal shroud, but even at the price, I may do this instead.
Or call:1-727 599-9399, or e-mail: jmuenze1@tampabay.rr.com
Jim
Old Aug 21, 2011 | 08:33 AM
Jim
Not correct! Plastic fan shrouds were for ALL A/C cars - NOT just 442's! Like i said earlier --- 330 A/C Cutlass' had them! Not sure if the statement about Lansing only and Calif cars is true or not? All I know is that my factory 67 Cutlass Supreme 330 A/C car had shroud on it from factory!!
Old Aug 21, 2011 | 09:08 AM
Dapapadon's Avatar
I don't know about other years.... I bought a 67 CS about 5 years ago, it didn't have A/C but did have a smog pump and it had the plastic shroud. That car had a lot of rust and I bought another 67 CS about a year later. It's in the garage, it didn't have a shroud when I bought it but it does have the two lower mounting tabs so I assume it came with one. This car doesn't have A/C either. Both cars were built in CA and were 330's. All of the 67 radiator top plates I've seen were drilled, or rather punched for the shroud.
If you want to adapt a 67 shroud to an earlier car I think you would need the two lower mounting tabs, the plastic shroud and a 67 top plate (or drill your's). I think there are reproductions of the shroud, but not sure.
Don
Old Aug 21, 2011 | 11:42 AM
2blu442's Avatar
Jeff, click on this link and scroll down toward the bottom of the page. It shows a source for repop shrouds for the 1964-65 Cutlass/442 and has some information on what they originally came on. Even though my car didn't come with one of these at some point I'm going to spring for one too as I like the idea of improved cooling during hot summer days! John
http://442restoration.homestead.com/Parts4Sale.html
Whoops! I just realized Jim already posted this information. Oh well, better to post it twice than not at all I guess!
Old Aug 21, 2011 | 11:58 AM
TripDeuces's Avatar
My 66 Cutlass has A/C and no shroud. 330ci with a clutch fan and idles at 197*
Old Aug 21, 2011 | 12:38 PM
2blu442's Avatar
I'm in no way an expert with 1964-67 vintage cars, but I believe we have a difference being missed. I believe, and you guys can confirm or correct this thought, that 1964-65 have the tanks on the top and bottom. That 1966-67 are a side flow with the tanks on the sides. I've not measured them but the side flow radiators in my 1967's looks larger than the top flow radiator on the 1965. Depending on the climate and time of year a shroud may be more important in some parts of the country. I haven't got my 1965 project car driving yet but my 1970 had real problems with stop and go traffic when the temp was pushing 100 degrees. I put in a 4 row radiator and a shroud with the clutch fan. That made a big difference.
Then the comment about what did or did not come with shrouds may also be a difference between the 64-65 vintage and 66-67 cars. I believe 442Bro is talking about the 1965 model when he said only the AC equipped 442's built in Lansing had the shroud. Hopefully this cleared things up some... if not please correct what I said and we'll go from there!
John
Old Aug 21, 2011 | 01:18 PM
Dapapadon's Avatar
Originally Posted by 2blu442
that 1964-65 have the tanks on the top and bottom. That 1966-67 are a side flow with the tanks on the sides. John
Good catch John, I should know better than posting on here after working the graveyard shift! He did say downflow, I read it but it didn't register. Sorry!
Now it's back to bed for me before I make more dumb postings!
Don
Old Aug 21, 2011 | 02:07 PM
jag1886's Avatar
Thanks for the info John, but I don't think I can get my butt cheeks spread that wide. I've been doing some research and it looks to me like there are several "heaven forbid" Chevelle ones that will do the job. Only a devoted Olds freak would know the difference by looking and I don't care.
Old Aug 22, 2011 | 06:48 PM
navvet's Avatar
My 64 88 with factory A/C does not have a shroud. For safety more then anything I would want one. Something simple as reaching into the engine compartment to check carb function while engine is running can be an accident ready to happen......not to mention the hood latch poaking you in the head while you examine the engine OOOUCH!!
Old Aug 23, 2011 | 05:35 PM
Jetstar 88's Avatar
That's odd, my 1964 88 does. Of course, it's the metal one that looks like a section of sewer pipe with some tabs welded on it, but it gets the job done.
Old Sep 4, 2011 | 02:32 PM
dhoff's Avatar
Shroud and Fan question?
When you add a shroud to a 71 cutlass that didn't come factory with one is there brackets that have to be attached to the bottom? I got a replacement one from Fusick, also a cluch fan since I got stuck in traffic and had my gauge reading 240 degrees with the 4 bladded factory fan. Or could I run the cluth fan without a shroud for a while till I get something to attach the bottom of the shroud to?
Old Sep 4, 2011 | 02:48 PM
Tucsonbob's Avatar
Where do you get the brackets?
Old Sep 4, 2011 | 03:22 PM
dhoff's Avatar
I don't have the brackets or if I knew what they look like I can fabricate. I didn't see anything listed in Fusick, or the Parts Place.
Old Sep 4, 2011 | 05:39 PM
navvet's Avatar
Hey JETSTAR 88
Any chance you can kick out a photo of the shroud? I went to an olds only car show last month and saw a few 88 of all types and no one had a shroud. Thanks
Old Sep 7, 2011 | 07:37 PM
navvet's Avatar
I have been looking at pictures from car shows and investigating other photos and have not seen one 63/64 88 with a fan shroud. Any ideas how I can find an example so I can fabricate one myself?
Old Sep 7, 2011 | 09:07 PM
2blu442's Avatar
Jeff, I don't mean to hi-jack your thread but wanted to answer a couple questions posted here
dhoff & Tucsonbob, here' a couple pictures of the 1970-72 tabs that the lower shroud bolts to. This core support is rusty, as are the tabs. But if you guys each wanted one with enough metal around it to help you fabricate new ones and weld them in the right location... contact me.
navvet, I recently looked at a 1965 jetstar and that year had something similar to a 55 gallon drum slice with corrigations in it. I don't know if that was the same as 63-64 or not. John
Old Sep 7, 2011 | 09:11 PM
Tucsonbob's Avatar
Thanks John. That is very helpful.
Bob
Old Sep 10, 2011 | 01:21 PM
jag1886's Avatar
I just got done installing a 66 Chevelle big block shroud in my 65 it fit real well only had to build some simple brackets to hold it in place.
Old Sep 28, 2013 | 05:15 AM
mphyle0927's Avatar
1965 dynamic 88 shroud needed. Where do I find one and what other cars can I adapt one from?
shamusj
Jan 13, 2015 05:44 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
