exhaust crossgver plugs
Old April 23rd, 2018, 03:48 AM
deadeyejedi's Avatar
three strikes and theyre out! ive had absolutely no luck with the cast iron crossover plugs that came with my 455 edelbrock manifold.we did a nice tight file fit and used a couple hi temp sealing methods around the port with felpro gaskets .after a long awaited spring cruise i can hear it starting to blow by again.at some point in the near future ill remove them and forget about it .there are more permanent fixes for this ,but for me its not worth the aggravation .plugging this crossover might make a difference in hundreths of a second at the track ,but for a street driven weekend warrior (imo)its just not necessary.
deadeyejedi is offline
Old April 23rd, 2018, 04:57 AM
72 Olds CS
RetroRanger's Avatar
I almost plugged mine when I did my BBO. Bit so many threads like yours made me decide against it. I was going to use the file fit as well.
RetroRanger is offline
Old April 23rd, 2018, 05:18 AM
toymobile's Avatar
Sounds like to much back pressure, mufflers to QUIET, pipes not big enough??
Just trying to help.
Johnny
toymobile is offline
Old April 23rd, 2018, 05:22 AM
W/z manifolds 2.5 exhaust with pypes mufflers .
Old April 23rd, 2018, 06:07 AM
x2
I've actually been lucky with the way I blocked the exhaust crossover though. I used soda cans wrapped around the gasket at the exhaust port. No leaks yet.
Olds64 is online now
Old April 23rd, 2018, 06:27 AM
edzolz's Avatar
If there is a metal supply house near you (or a sheet metal fabrication house) try to get a piece of 321 stainless sheet that is 18 or 19 gauge thick. Cut out some rectangular pieces large enough to cover the openings and slip them between the gasket and the head. The heat generated by the exhaust isn't hot enough to melt the stainless and they should last a long time.
edzolz is offline
Old April 23rd, 2018, 06:36 AM
My442's Avatar
My machine shop made a set of block off plates from 1/8" thick steel.
Shaped them to a press fit into the cross over ports.
Been in there for 8 years with no issues.
There are thick enough not to burn thru.
My442 is offline
Old June 11th, 2018, 05:45 PM
finally got around to pulling the intake and removing those plugs.embarrassing driving around with that awful clacking. worse part about the job is cleaning off all the old gaskets.i also need a better way to drain the radiator ,you turn your back on that petcock and its either dribbling all over the floor or shooting past the catch pan lol
Old June 11th, 2018, 06:32 PM
OLDSter Ralph's Avatar
Slip a piece of rubber hose on the end of the petcock. How long ? As long as you need it to drain to your choice of locations.
OLDSter Ralph is offline
Old June 12th, 2018, 07:22 AM
83hurstguy's Avatar
Mondello sells stamped sheet metal that fits into the oval opening on the early head crossover when using fiber intake gaskets. HR-351 is the part number. I would not endorse Mondello for anything, but I bought these and they seem to work pretty well.
83hurstguy is offline
Old June 12th, 2018, 09:32 AM
I shaped a couple blocks of aluminum and had them welded into the intake manifold crossover ports.
Fun71 is offline
Old June 12th, 2018, 11:40 AM
Thanks for the suggestions I will try a more permanent solution on the 455 I’m building now . Hopefully I won’t have to open this motor up again anytime soon.for a street car I’m plenty happy with it as is
Old September 29th, 2018, 04:59 PM
for whats its worth i talked to B mondello about these plugs and was told they should be ground down just enough that the plug would be sticking up above the head 1/4 to3/16 of an inch and then pound them flush with a good sized hammer then seal with hi temp silicone. when i did mine all i had to do was lightly tap them flush which is why they ultimately failed .lesson learned
Nasty455
January 9th, 2013 05:56 PM
Dant
June 27th, 2011 01:38 PM
cleancutty
July 26th, 2010 09:59 AM
ELECMAN
April 5th, 2010 07:14 PM
silverriff
September 30th, 2008 03:30 PM
Quick Reply: exhaust crossgver plugs
