Exhaust
Old Sep 10, 2014 | 05:07 PM
Gary M's Avatar
Exhaust
I have the X pipe and sounds like a truck. Heard somewhere that Walker mufflers are good. I need to have less sound in the cab and a good sound out back. Want stainless steel. Any suggestions?
Old Sep 11, 2014 | 06:34 AM
I've got Walker Turbo 2.5"s on mine. Very quiet at idle and cruise, push the fun pedal down and they wake up.
Old Sep 11, 2014 | 06:37 AM
Call Gardner exhaust. They make the exact sound exhausts as the car came off the assembly line with. Stainless or regular steel. Finest Olds exhausts made.
Old Sep 11, 2014 | 02:55 PM
'69CutlassVert''s Avatar
Allan, what does that system run? And is it manifold to rear tips?
Old Sep 11, 2014 | 03:35 PM
Are you going to change the X pipe setup to a more stock type or run with the exhaust as it is and just change the mufflers?
Old Sep 11, 2014 | 05:25 PM
Gary M's Avatar
I want to remove the X pipe and mufflers as one piece because they are Aluminized,welded and not very old. I think I will cut the pipes past the rear of the mufflers on the upswing over the rear end so someone can maybe reuse them. I want to use true duel exhaust, stainless if possible with a good sounding note. I just don't like the resonating of the exhaust inside the car.
Old Sep 11, 2014 | 05:37 PM
I know the x pipe gives a different note but the drone may be cured just by changing the mufflers.
Old Sep 11, 2014 | 05:40 PM
Gary M's Avatar
The mufflers are supposed to be stock. That would be great if it was that simple. I am trying to upload a video of it idling but having trouble.
Old Sep 11, 2014 | 05:50 PM
Gary M's Avatar
I also have Dynomat installed.
Old Sep 11, 2014 | 05:55 PM
I run a true dual exhaust (custom) with the Walkers and it's pretty quiet. I can hear my stereo.
Old Sep 11, 2014 | 05:56 PM
Gary M's Avatar
My video is missing a security token. Can you help?
Old Sep 11, 2014 | 05:59 PM
I don't understand the security token thing. Do you have a photo sharing site that you can copy the url from and post it?
Old Sep 11, 2014 | 07:00 PM
Eric Gardner would be the one who could give you the quote, based on what you want. It's a complete system from manifolds to tips.
Here's his phone: (845) 758-8003
Old Sep 11, 2014 | 08:10 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I started a thread on here last week about those stupid security tokens. It is the settings on your computer and has something to do with cookies. I could not post pictures and got that stupid token message. I went in a clicked on enough stuff that it finally worked.
atkinsom
May 29, 2013 06:39 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
Chuck C
Sep 1, 2004 07:37 PM
EdsDelta
Jul 22, 2004 11:46 AM
