Engine run stand wiring
Old Apr 18, 2021 | 08:05 AM
68442's Avatar
Wiring up a run stand from scratch. Question i have is what do i run to the coil? for ignition, Straight 12 volts or does it need to run through ballast resister. On line diagrams show both ways. Working with points distributor.
Old Apr 18, 2021 | 08:32 AM
For the short time that you'll be running the engine on a stand, full 12V to the points is fine. The whole point of the ballast resistor is to drop the voltage to extend the life of the points. For the 20 minutes it takes to break in a cam, it won't matter.
If you're determined to run a resistor, then you need two separate wires from the ignition switch, one that provides full 12V in START and one with a resistor in RUN.
Cutlass Fan
May 2, 2021 04:42 PM
williamwallace11
May 2, 2021 04:38 PM
FSTGeek
May 26, 2014 08:58 AM
liquidpower
Dec 30, 2010 09:20 AM
Jolly Green
Feb 13, 2008 12:33 PM
