engine number decode
There is no way to tell that from the VIN. You would need the build sheet or broadcast card (I think. I know that works with W30 and W31 cars) and it should have - - for the paint code on the plate that is riveted to the firewall.
This is the VIN derivative for a 1975 model year motor from the Arlington, TX assembly plant.
And as noted, a 1970 Cutlass Holiday Coupe from Lansing.
And that's a 1968-1976 Olds 350 block casting number.
pfergy600
September 28th, 2013 07:47 PM
Flye
Drivetrain/Differentials
20
November 25th, 2009 10:05 AM
1BAD68"S"
September 17th, 2006 06:49 AM
