engine number decode
Old Jan 8, 2016 | 04:51 PM
nisszx's Avatar
Hi can any one decode my engine number for me please it is 35R137093 I think it is a 350 well it should be
Cheers
oz Bill
Old Jan 8, 2016 | 06:01 PM
lemoldsnut's Avatar
If that is the vin tag number that won't do much for you. Get the casting number off the block behind the water pump and next to the oil fill tube.
Old Jan 8, 2016 | 06:40 PM
nisszx's Avatar
engine number
Hi that is the number on the engine block by the power steering pump the vin number is 336870m256038
Cheers
oz Bill
Old Jan 8, 2016 | 06:44 PM
svnt442's Avatar
OK, so you have a 1970 cutlass with a 1975 engine. What we need to tell you what the engine is will be the number that is cast into the shelf behind the water pump next to the oil fill tube.
Old Jan 8, 2016 | 07:44 PM
nisszx's Avatar
Smile engine number
Hi the number cast into the block is 395558
Cheers
oz Bill
Old Jan 8, 2016 | 07:46 PM
nisszx's Avatar
rallye 350
Hi the car is a rallye 350 whether that makes a difference I don't know
Cheers
oz Bill
Old Jan 8, 2016 | 08:08 PM
tru-blue 442's Avatar
Old School Olds
That's the #'s for a 350.
Old Jan 8, 2016 | 08:25 PM
nisszx's Avatar
help
Hi thanks for all your help
Cheers
oz Bill
Old Jan 8, 2016 | 08:31 PM
svnt442's Avatar
My guess would be that it has #8 heads on it, unless they were swapped out at the time of the engine swap.
Old Jan 8, 2016 | 08:34 PM
svnt442's Avatar
Cheers
oz Bill
There is no way to tell that from the VIN. You would need the build sheet or broadcast card (I think. I know that works with W30 and W31 cars) and it should have - - for the paint code on the plate that is riveted to the firewall.
Old Jan 9, 2016 | 07:11 AM
35R137093
This is the VIN derivative for a 1975 model year motor from the Arlington, TX assembly plant.
And as noted, a 1970 Cutlass Holiday Coupe from Lansing.
And that's a 1968-1976 Olds 350 block casting number.
ironlou399
Aug 9, 2019 01:08 PM
pfergy600
Sep 28, 2013 07:47 PM
Alg
Jan 1, 2013 05:04 PM
Flye
Drivetrain/Differentials
20
Nov 25, 2009 10:05 AM
1BAD68"S"
Sep 17, 2006 06:49 AM
