Engine/coolant temp question
Old Jul 20, 2024 | 09:47 PM
Mikeyt's Avatar
Mikeyt
1962 98 394ci 4v
Went for a 3 hour cruise tonight and all was well until I got home and tried to pull her up on jack stands and the water pump started puking coolant.
Checked temp at top hose was around 190, front of cylinder heads was 205 and bottom radiator hose was at 160.
New radiator, hoses and 160 thermostat.
Are those Temps normal?
I had to push her pretty hard to get up the ramps and checked Temps right after.
Old Jul 21, 2024 | 03:39 AM
Those are normal temps. If the water pump is leaking, it's time to repair/replace it. If the coolant is coming from the radiator overflow, you probably overfilled it.
Old Jul 21, 2024 | 04:51 AM
Mikeyt's Avatar
Mikeyt
Thanks man
Yeah, it's leaking from the center of the pump behind the fan.
Someone was watching over me for sure. I was down some dark, secluded roads and the pump gave out right in the driveway.
Old Jul 21, 2024 | 05:21 AM
Dry everything up and start it and make sure the leak is from there. A lot of stuff gets soaked and drips from its lowest point naturally.
Old Jul 21, 2024 | 06:52 AM
Mikeyt's Avatar
Mikeyt
I'm 99% sure it's the pump. I added water to the radiator and it just poured out of the same area.
everything above that is dry.
Super88chris
Oct 31, 2023 03:45 PM
OA5599
May 30, 2020 03:14 PM
smash72
May 25, 2019 12:54 PM
tds
Jul 14, 2015 09:11 AM
olds307owner
May 17, 2007 07:48 PM
