Engine accessory paint, air cleaner, brackets, etc.
Old Sep 10, 2015 | 08:58 AM
mcox8051's Avatar
'72 Cutlass Supreme 442. Came with 350 now has a '72 455. I searched the forums and couldn't find any references to paint types, ie: gloss, semi-gloss, satin....for the breather, alternator bracket, A/C brackets. I did see someone said Eastwood ceramic paints are best to use. Is there a guide on what types of paint to use on what? Thanks for the help.
Old Sep 10, 2015 | 09:37 PM
2blu442's Avatar
Look through the major builds section. There have been a couple members post very detailed restorations on 1970-72 cars and you should be able to read what they used.
John
Old Sep 11, 2015 | 05:04 AM
mcox8051's Avatar
Thank you!
Old Sep 11, 2015 | 06:09 AM
JpMotorsports's Avatar
From what I saw from pics of other motors I mainly used semi gloss on most pieces
Old Sep 11, 2015 | 06:11 AM
bolts and nuts I mainly sprayed with a cast iron gray
Old Sep 11, 2015 | 08:49 AM
mcox8051's Avatar
Looks good! Thanks for the tip.
Old Sep 11, 2015 | 09:17 AM
I did use the eastwood high temp ceramic engine enamel. I did spray it using on of the hobby aerosol can sprayers with a little reducer. all the bolts and hinges were sprayed with eastwood cast and detail grays. The black pieces were sprayed with vht high temp engine paint. The exhaust manifolds were painted with por15 manifold paint.
68 D88
Feb 16, 2015 05:20 AM
QS442
Nov 23, 2013 07:45 PM
Mocephus
Dec 2, 2012 09:46 AM
69CutlassAlex
Dec 2, 2011 08:01 AM
pontiac1
Dec 24, 2009 07:25 PM
