Embarrassed to ask.
Embarrassed to ask.
I need some help on this one.I like many have had issues with an improper Fuel Gauge reading.I have replaced my Chinese Fuel Sending Unit with one from my Friends at Fusick.I have a good ground .I have elevated the float outside of the tank and get an acceptable reading at the Gauge.
When I install the sending unit into the tank.And secure the Clamping Ring I am once again at a Null position or Empty with no movement at the Gauge.
My question is this.Where does the Rubber Grommet belong.Between the Tank and the Sending unit .Or between the sending unit and the Metal Clamping Ring.
Thanks in advance
Ron Roth
Thanks in advance
Ron Roth
A gauge stuck on E indicates a short circuit.
The purpose of the rubber grommet is to seal the joint between the sending unit and the tank, so that's where it should go. I'm not sure how you're even getting it to fit anywhere else.
To check the wiring between the gauge and where you disconnect the sending unit wire. Disconnect the wire at the sending unit. As Old Cutlass said the gauge will go past full with the key in the on position. Take a jumper wire and ground the wire that goes back to the gauge. The gauge should move to E.
I'm with you guys.When the Sending unit was unattached to the tank "Ground intact' I could get reading 1/4- 1/2-3/4 and Full by manually raising the float.I reassembled the sending unit and he seal into the tank and now get an E Reading.
My Nickname growing up was the Doctor.All my Friends said I had Patients..Or was it Patience..Any way thats all it took.. Went out the Pole Barn ..Pulled the Old Lady down from the rack.Turned the Ignition Started her up..And we have a reading I am comfortable with..Thanks to all that had some input..Especially the Guy from Tennessee Jack Daniels..
lshlsh2
November 14th, 2010 03:08 PM
oldsdroptop
September 1st, 2009 06:38 AM
64 Cutlass
August 10th, 2009 05:18 PM
