Electrical issues
Old Jun 5, 2009 | 07:53 PM
tim72's Avatar
Electrical issues
Having a problem with my battery running down. When I attach the positive to the post the Voltage regulator starts Clicking. I have replaced the starter and alternator and voltage regulator. They are wired correctly. I have a Msd ingnition,coil and box. They seem to be wired correctly. The car starts and runs. Any sugerstions on where to start looking for the problem?
Tim
Old Jun 6, 2009 | 04:34 AM
My442's Avatar
Pull the negaitve battery terminal, and place a 12 volt trouble light tester between the post and the cable end. If there is a current draw, the light will be on.
Then start to pull fuses one by one until the light goes out. That curcuit is where the electrical draw is.
The only electrical draw should be a clock or an aftermarket radio, with the key off.
Old Jun 6, 2009 | 01:18 PM
tim72's Avatar
Electrical issues
I found that when I take the red wire running from the solenoid to the horn relay off the test light does not come on. It looks as though the issue is from the starter to horn relay. I changed the relay off another car and that was not the issue. The starter wires are correct and not touching any thing to cause a negative ground. The starter is brand new with new solenoid and the car starts. Is there a need for the redwire from the starter to the horn relay? My other 72 does not have this connection just the red from bat and the two wires from the wiring harness. Probably a stupid question. The procedure you gave was very good. I do not claim to know how to fix electrical but because of the economy I am trying to figure it out with a lot of help from the list.
Tim
StarGeneral
Nov 30, 2011 03:55 PM
1968Cutlassfallbrook
Jul 30, 2011 04:15 AM
Beob
May 16, 2011 06:43 PM
yeahbuddy
Apr 21, 2010 06:32 AM
silverriff
Apr 14, 2010 09:49 PM
