1968 cutlass Electrical issues
Hello all,
I have recently replaced my headlight switch and since I have done that I have noticed that I have a weird sound as it sounds like grease frying but I haven't been able to locate the area that it's coming from. The dash lights didn't all work only the clock light worked now that all lights work with the new switch I have that noise. Also I have noticed that the switch isn't as tight as the factory as it seems to have some play in it. Does anyone have an idea what could be the problem? I have felt the wires on the headlight switch from where I can touch but I can't go any further as the wiring harness being taped. Any info on how to check what could be going on that would be wonderful. Thanks Also What size of battery cable would be a good one as I believe mine is the factory thickness my friend thinks I should go thicker. Thanks
John
John
I was wondering what's the best way to tackle the under dash wiring as I believe I have a serious short as I have noticed some serious ark on the positive battery terminal and it's been turning black. should I pull the complete dash out and inspect everything or would it be better to get a new harness or what should I do? Thanks
John
John
John
John
Putting the dash back in takes longer and a lot of patience
If you take the dash out the ignition (& every other switch) comes out with it
It's easier if you remove the steering wheel, but no, the steering column doesn't need to come out. Obviously the dash pad comes out too. There's like 7 speed nuts and a push pin & some of them suck to get to but they are all accessible
is there any trick to get the ignition switch wires off as I have been trying to pull them off just can't get them to slip over the holder. Also what other parts do I need to discounect I know the speedo and what else is there.
And yeah....pulling the front seat (especially the driver's side) makes it a lot easier
Just out of curiosity, what makes you think the short is in the dash and before you go through all this can you isolate the "crackling" sound source. That could just be a bad ground. Are you sure about the positive battery connection being fried? The frying usually takes place in the smaller wires that heat up faster
I have been trying figure out what wires go towards the back is it the purple wires? Also is there a clip or do I need to take the fuse box apart to get to take the back wire harness off. I haven't done any electrical work before or should I leave it to someone who knows what their doing. I was wanting to check for any burnt wires or anything that looks like it could be having an issue. Also if I take it to someone would they need the car to test the wiring or could they just look at it and know what wires are wrong. As I'm on a tight budget and wanting to save some money if I can.
If you've never done any wiring before & you don't consider yourself mechanically inclined you should let someone else do it. If you want to try it yourself you need a volt/ohm meter & a 68 wiring diagram. I sent you a PM. I can send you a wiring diagram if you give me your e-mail address
Mike
Mike
I finally got all the nuts off of the dash to pull it what connectors do I need to take off to pull it out with the gauges and wiring attached? I pulled the heater/ac control panel and pulled the door switch light off. Any advise or photos would be great.
Well I do have the dash out and I started taking the old tape off and I noticed that there are a few areas where there are either 3 or 2 wires going into one wire that is solder together is this factory or someone who mickey moused it. Also I have noticed my clock doesn't work and I took it apart and sprayed some wd40 and pushed down on a part that has a spring and the second hand moves until it hits the top but doesn't reset could the coil be bad that gets the power? Any advice to get this wiring issue fixed. Also who do you recommend to get gauges checked out by to make sure they're calibrated and working correctly? Also anyone have someone to recommend on restoring the dash pad?
Those are original splices.
The clock probably has burned contacts or a burned out coil.
The coil can be unwound until the bad part is found (usually right near the end) and re-soldered. There is a lot of on-line information about this.
