Edelbrock Torker vs. Edelbrock Performer
Old July 21st, 2013, 06:28 PM
69CutlassAlex's Avatar
I have a 455 with .472 Edelbrock Cam and lifters, 750 cfm Edelbrock carb, headers and a few other small upgrades and soon a set of C heads with a lot of performance mods. Which intake would be a better choice. I already have the Performer. Any experiences?
69CutlassAlex is offline
Old July 22nd, 2013, 09:07 AM
The Performer is your best bet compared to the Torker single plane. The Torker will not work with Ram Air setups according to the Edelbrock sight.
oldcutlass is online now
Old July 22nd, 2013, 10:07 AM
chadman's Avatar
For your application I would run the performer especially since you already have it. If you were running more cam like around 230 or more at .050 then I would run the Torker.
chadman is offline
Old July 29th, 2013, 01:59 PM
I am looking to put in a bigger cam. Looking at either .49 or .51 lift. The Edelbrock performer RPM range is Idle-5500. Any cam that is bigger than the .472 which I already have has an RPM Start Range of 1500 or higher. I would assume that putting a bigger cam with a higher RPM range with my current Edelbrock performer would be a bad idea? Thanks all
Old July 29th, 2013, 02:48 PM
Is your engine going to run at 6500+ rpm? If not then the Performer is the manifold for you.
Old July 29th, 2013, 05:59 PM
Even if I put a bigger cam in? My main concern is the initial overlap. Having a idle-5500 intake and a 1500-6500 cam. Is that slight offset bad? Don't you typically want a match RPM Operating range?
Old July 29th, 2013, 06:39 PM
It's a package, here is a good article but read the whole thing:
http://www.enginelabs.com/engine-tec...or-dual-plane/
Old July 30th, 2013, 04:47 AM
chadman's Avatar
For what you are doing there will not be an appreciable difference. If you were looking for better times at the drag strip I would go with the Torker but for a mild street car you won't notice a "seat of the pants" difference. You said you are looking to change cams but only listed possible lift numbers. It's more the duration @ .050 and the LSA that determine the "attitude" so to speak of the cam much more so than the lift.
chadman is offline
Old July 30th, 2013, 08:18 AM
ok thanks, Currently Ive got so much torque I don't know what to do with, so im looking to up my midrange performance. My Current Cam is(duration/lift/lobeseperation)214° / 224°.472" / .496"112°
I also read that the camshaft and the Intake don't have to be exactly matched when it comes to RPM operation range but its good to have it within 500-1000 RPMs.
classicjoe
May 5th, 2013 06:28 PM
rhurstolds74
January 20th, 2013 03:39 PM
455cutlass1969
April 9th, 2012 11:13 AM
70Cutlass_408
June 24th, 2011 07:55 AM
alek72us
March 1st, 2011 05:50 PM
Quick Reply: Edelbrock Torker vs. Edelbrock Performer
