Edelbrock Carb
Edelbrock Carb
I am running a 1411 edelbrock 750cfm carb. with a 455 bored 40 over and edelbrock heads. I believe I need about 825 to 850 cfm. Can I make adjustments on this carb to achieve it? No Carb sight so I put it here.
Tim72
Tim72
What makes you think you need more carb?...I have the same carb on my 455...040 over 9.5 -1 pistons...No edlebrock heads but C heads all done up.
I had to lean mine out...too rich...they are adjustible with jets and rods in a kit...if you use a air fuel guage for the adjustments you can get it to run real nice...Mine is awesome ...
Looked into the holley and the guy there said the Holley 750 hp or avenger 770. I have not heard a lot of good things about the avenger. So go with a mechanical ?
Tim
70Cutlass_408
Jun 24, 2011 07:55 AM
