ebay 67 442
Old Jan 26, 2019 | 07:41 AM
vickycar's Avatar
ebay 67 442
guys i noticed this 67 cutlass 442 convertible on ebay today and there is a numerous amount of pictures to look at. a side from the stripping being totally incorrect it looks pretty much like a 442 from under carriage up. but looking at pic of cowl tag, do not see 5v on tag just 5y. can the experts chime in on this ,i was lead to believe no v no 442. if that's the case someone did a lot of work cloning. THOUGHTS???
Old Jan 26, 2019 | 08:58 AM
scottv442's Avatar
Maintained
i thought the 'V' stood for 4spd. trans only?
442 that year could be automatics too.
Old Jan 26, 2019 | 09:45 AM
All 1967 442s EXCEPT those built at Fremont got the 5V cowl tag code. Fremont for some reason did not use that code. Unfortunately, that means that there are now about ten times as many Fremont-built 442s as were actually made. Unfortunately, unless you post a link to the auction, it's difficult to give you thoughts on the car in question.
Old Jan 26, 2019 | 11:53 AM
hurst68olds's Avatar
https://www.ebay.com/itm/1967-442/26...7:pf:0&vxp=mtr
this one? "CLONE" was 330 4bbl automatic
Old Jan 26, 2019 | 12:31 PM
vickycar's Avatar
yes that's the one, good job clone
Old Jan 26, 2019 | 01:41 PM
lemoldsnut's Avatar
This tag clearly has the code for ST300 trans which did not come in 67 442 and to be a numbers matching car it has a 4 speed. and the wrong air cleaner. It is nice but, a clone.
Old Jan 26, 2019 | 01:45 PM
I'd like to know what numbers "match" on a 67 anyway...
Old Jan 26, 2019 | 01:49 PM
Old Jan 26, 2019 | 01:56 PM
Originally Posted by hurst68olds
If you're lucky...
Old Jan 26, 2019 | 02:55 PM
edzolz's Avatar
No matter how nice it is, someone is going to get screwed thinking they have bought a real 442 with "matching numbers".
Old Jan 26, 2019 | 03:10 PM
66-3X2 442's Avatar
I have a numbers matching 66 442 3x2. The vin matches the protecto plate,the protecto plate has the engine ID # that matches the engine/head in the car.
Old Jan 26, 2019 | 03:26 PM
I KNEW someone would post this...
You and I know that, but I guarantee this seller (and most people) have no idea what a P-O-P is. Do you really think the ebay car has a P-O-P?
Old Jan 26, 2019 | 03:28 PM
66-3X2 442's Avatar
That wasn't the question. You said what does numbers matching mean on a 67 and I just answered your question. Just havin a little fun.
Old Jan 26, 2019 | 05:06 PM
I know.
Here's another example. Per the P-O-P, my 67 Delta is "numbers matching", despite the fact that the engine is a 1969 455. The only engine part that's original to the car is the passenger side cylinder head.
Old Jan 26, 2019 | 06:32 PM
66-3X2 442's Avatar
I know.
Special order I guess.
Old Jan 27, 2019 | 06:27 AM
68442's Avatar
What does the 5Y represent?
Old Jan 27, 2019 | 06:53 AM
The 67-older cowl tags had five "groups" for Fisher Body accessory codes. The "5" represents Group 5 (note that the "1" for Group 1 accessories was left off on those). The V represents RPO W-29. The Y represents deluxe seat belts.
On that particular cowl tag, the "W" is really a Group 1 W, which represents tinted windshield.
The "2XG" represents Group 2 X - floor shifter for automatic trans and Group 2 - G for console.
Obviously this car is not a factory built four speed, nor is it a factory built 442.
Old Jan 27, 2019 | 07:21 AM
Kennybill's Avatar
Car did not meet the reserve.
Old Jan 27, 2019 | 07:25 AM
No, actually the seller ended the auction claiming that the listing was in error and relisted it with new info. The "matching numbers" claim is gone and the ad now says " *L78 442 PACKAGE(ADDED) ". Apparently the seller either reads CO or someone else called BS.
https://www.ebay.com/itm/1967-442-/2...d=264157161954
Old Jan 27, 2019 | 08:56 AM
ts71442's Avatar
Car was purchased at Mecum Kissimmee a few weeks ago for $34,100 including buyers premium. Looks like a dealer did not pay enough attention to what he bought!
https://www.mecum.com/lots/FL0119-35...2-convertible/
Old Jan 27, 2019 | 09:09 AM
Kennybill's Avatar
Hmmm "numbers matching 350hp 4-speed" says it right across the windshield. That must be an optical decal package.
Old Jan 27, 2019 | 09:20 AM
Well, someone's going to be sadly disappointed...
That "original drivetrain" should have had an open element air cleaner on a 4spd car. The aftermarket small diameter brake booster is also an issue. The dash pad has obviously been painted, since it doesn't match the glovebox in color or gloss. And a factory M21 car would have come with a 3.91 rear axle.
Old Jan 27, 2019 | 09:23 AM
Previously the auction title said "numbers matching". Now it doesn't. Obviously he just reused the same photos.
TDS_1
Nov 2, 2018 09:27 AM
cincyrick67
Feb 4, 2016 06:06 AM
BionicSnoopy
Sep 21, 2014 01:10 PM
Oldsmaniac
Jul 16, 2014 11:45 AM
67Olds442X2
Feb 1, 2011 06:10 AM
