Easiest blower motor repair ever
It's no secret that my 72 hasn't scorched any asphalt for a few years now. Since I uncovered it this year I've been slowly getting my ducks in a row to turn the key and hit the road.
One of the things that I needed to fix was the no fan condition except on high position. Typically this is 99.9% the resistor for the blower motor (non AC car) which is located on the top of the air plenum.
I ordered a new one from ILT and yesterday went to install it. I reached up behind the lower dash to see if I could get to the wiring and screws without removing the glove box. That's when I had a WTH moment. The pigtail was hanging down and wasn't connected to the resistor. Took all of 30 seconds to feel the connector position and lock it back on. Test the fan and BAM! It works on all speeds again. So now I have a spare resistor in case it fails. I'm impressed that the 45 year old part is still working as when new.
If I had tried to remove the resistor to test the various poles, I guess I could have solved the problem earlier and avoided the cost of a new one.
Truth is I hardly ever use the fan in the car. Usually when I take it for a cruise I have all the windows down, and I don't drive it in cold weather. If I did, the heater would be on high, which is a direct 12 v feed to the fan switch.
I'll never know for sure. I'll be pulling the aftermarket one and installing OEM AM/FM with front and rear speakers, along with the 8track. Just need to recone the 10 ohm speakers.
I have your repair beat.
When the blower motor in my 84 Delta 88 stopped working on every speed, I bought a new one.
Before I installed it, I was telling my Dad about it. He walked over to the car lifted the hood and gave the blower plenum a good blow with his right fist.
Problem solved. The fan continued to work from that day and every other day until I junked the car after it rotted out all around me.
Fast forward 13 years and I found myself working on my 83 Wagon project. The blower motor was rusted solid and wouldn't even turn by hand. But the Olds replacement I've had on the shelf all these years matched up and got bolted in.
I recently had trouble with my blower not blowing, after assembly, getting my build together. I was stumped, everything had power except the blower motor, which is new. Two harnesses, one to the resistor and the other to the high speed relay. Each has a 3 prong plug and a single prong, now its been 4 years since I took it apart. Each 3 prong plug will fit only the part intended, resistor 3 prong will not fit the relay and visa versa. So I assumed the single prong plugs also went on the same part as the 3 prong, but I was wrong. The single resistor plug goes to the single relay, and the single relay plug goes to the single resistor, and then, the blower blows! Something so simple but at least for me was difficult to see.
1Fastolds
Ninety-Eight
Jun 9, 2014 09:12 PM
