Dyeing seat belts
Old Apr 25, 2015 | 01:21 PM
GINCSC's Avatar
Dyeing seat belts
anyone ever dye the seat belts. I cleaned mine and now they look ok but faded.
Old Apr 25, 2015 | 04:19 PM
RandyS's Avatar
Yes, you can use the SEM vinyl/fabric paint on them and they turn out great.
Old Apr 25, 2015 | 05:47 PM
crimsoncolby's Avatar
I am curious how long the SEM paint will hold up under constant flexing of the material. Also, doesn't it make them stiff?
I've had success dyeing faded black straps same color using an "acid" dye from a company called Jacquard. The "acid" is nothing more than white vinegar added to the simmering pot of water/dye solution. Trouble with this method is that the plasticized fibers of the webbing will not, by nature, absorb color. It's more like staining the fibers enough to revitalize the original color...but, not enough to change to a different color.
Old Apr 25, 2015 | 08:11 PM
oldstata's Avatar
Justin
I have not tried this!
I have read on the Chevell sight, about shoe polish to dye seat belt webbing. here is one link I just looked up might need to cut and past
http://www.chevelles.com/forums/showthread.php?t=344812#/forumsite/20668/topics/344812
Old Apr 25, 2015 | 08:58 PM
I remember reading this post when I was researching info on how to rejuvenate my belts. I was very skeptical of the shoe polish not rubbing off on my (or, my passengers') clothes. Again, the webbing is not a porous fabric where the polish would bond tightly to the material; such as with leather. But, who knows.....
Fortunately, I have since learned how to fully disassemble the retractor spools to remove the old straps...and, have a friend who can get me newly sewn straps from a guy who has experience making racing belts if I provide the buckle ends. All, for a fraction of the cost of sending them to the well-known belt restorers.
Old Apr 25, 2015 | 09:12 PM
RandyS's Avatar
The SEM paint is pretty durable. It soaks in to the fibers of the webbing and does not change the texture or pliability at all. Dries very fast too, as in minutes. You don't need to disassemble anything, spray one section then after it dries pull that section thru the buckle to expose the area that hadn't been done yet. If you accidentally get a bit on a metal part, clean it off with acetone. I have only used black on black belts, so I don't know if it would be suitable to change a color.
Old Apr 26, 2015 | 06:32 PM
501Paratrooper's Avatar
I did this as well, but cleaned them very well first. Soaked in a water tide solution for a day or two and then in my wife's dishwasher for a cycle. Worked great!
Old Apr 26, 2015 | 07:31 PM
marxjunk's Avatar
RIT dye....dye is dye..paint is paint
rit is in the grocery store and cheap
take a gallon can mix the dye and put on the stove til boils lighty..not rolling..
wet the belts stick them in the dye, let cool..pull belts out lay on a rail or line,,,when dry..use them..done it a bunch..works well..have had them done in some of my cars for nearly 2 decade with no issues
belts need to be wet for proper penetration
Old Apr 27, 2015 | 01:04 AM
rustyroger's Avatar
'87 Delta 88 Royale
I think it would be unwise to use anything that reacts with the webbing, perhaps replacing the belts with new ones should be the ideal solution.
Just from a safety standpoint, how long before seat belts start deteriorating enough to compromise their effectiveness?.
I think it probable that belts fitted to passenger aircraft have a limited lifespan, of course standards are far higher than for road vehicles, but nothing lasts forever.
Roger.
Old Apr 29, 2015 | 03:20 PM
GINCSC's Avatar
Found a set for 269.00
http://www.ss396.com/chevelle/SBL-CH...8KYhoCXpnw_wcB
I think that's the route I'm going to go.
new and safer.
after spending a billion dollars restoring this car why cheap out on seat belts.
thanks guys,
Gary
Old Apr 30, 2015 | 12:21 AM
rustyroger's Avatar
'87 Delta 88 Royale
new and safer.
thanks guys,
Gary
I applaud your decision.
I hope you buckle up every trip, and never need them.
Roger.
jcmoretti
Jul 11, 2018 03:07 PM
69442murph
Jan 19, 2013 11:55 AM
dfire25
Nov 18, 2012 05:24 PM
sx455raidercelticfan
Dec 21, 2010 08:59 PM
Joffroi
Sep 10, 2010 05:44 PM
