Dual gate shifter problems need help
Old Feb 3, 2015 | 06:46 AM
akins2000's Avatar
Hello i install a new oldsmobile dual gate shifter and cable. 3 speed shifter and 350 transmission. I had replace the original cable to the new cable And nothing is match up when i cange gears. Park work fine. Do i need to change the cable bracket on my transmission if so what does it look like because that was the only thing i didn't change or can the cable be adjusted.
Old Feb 3, 2015 | 07:44 AM
toymobile's Avatar
What type shifter did you remove?? Did you have an original cable with the other shifter?
Old Feb 3, 2015 | 08:01 AM
akins2000's Avatar
It had the original standard 3 speed floor shifter and cable. The original cable i think was short for the dual gate
Old Feb 3, 2015 | 08:20 AM
toymobile's Avatar
Some adjustment on the cable at trans bracket but not much, where the cable attaches to the shift lever, takes 1/2 wrench to loosen, can move about 1/4in maybe you can get the setting you need?? Good luck.
Old Feb 3, 2015 | 12:04 PM
You need to ensure that you have the correct cable for the Dual Gate. By your description of having a longer cable now, it may be correct.
There is an slot on the transmission end of the cable that allows some adjustment.
Here's a pic showing the linkage and the adjustment:
https://classicoldsmobile.com/forums...-switches.html
chasman414
Jun 25, 2020 07:05 AM
jensenracing77
Mar 22, 2015 04:52 AM
akins2000
Feb 11, 2014 01:07 PM
ziff396
Sep 22, 2009 08:06 AM
