Dual gate shifter problems need help
Hello i install a new oldsmobile dual gate shifter and cable. 3 speed shifter and 350 transmission. I had replace the original cable to the new cable And nothing is match up when i cange gears. Park work fine. Do i need to change the cable bracket on my transmission if so what does it look like because that was the only thing i didn't change or can the cable be adjusted.
Some adjustment on the cable at trans bracket but not much, where the cable attaches to the shift lever, takes 1/2 wrench to loosen, can move about 1/4in maybe you can get the setting you need?? Good luck.
You need to ensure that you have the correct cable for the Dual Gate. By your description of having a longer cable now, it may be correct.
There is an slot on the transmission end of the cable that allows some adjustment.
Here's a pic showing the linkage and the adjustment:
https://classicoldsmobile.com/forums...-switches.html
ah64pilot
May 29, 2012 03:04 AM
