Doughnut or Gasket used on Ex Manifolds?
Old Jul 18, 2022 | 07:06 AM
Burd's Avatar
What is typically used on the exhaust manifold to pipe, any gaskets or is it a flange fitting on the olds, a buddys doing the 403 in a TA.
Old Jul 19, 2022 | 03:49 AM
To be honest, I'm not completely sure on the T/A manifolds. It's easy enough to tell. If the manifold outlet has a metal tapered feature, no donut is used. If it has a flat surface with a counterbore, then one is used. The A-body cars did not use donuts. Other Olds cars did (my 67 Delta, for example, uses donuts).
Old Jul 19, 2022 | 06:15 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If the outlet is straight down, usually with 3 bolts, it requires a donut. Most of the 70's with catalytic converters and definitely all the 80's Olds V8 used this configuration.
Old Jul 19, 2022 | 07:15 AM
Burd's Avatar
Hey thanks. I’ll get A shot of the pipe or manifold and post it up.
Old Jul 19, 2022 | 07:28 AM
69HO43's Avatar
My source say it should originally have been a 563519 p/n for 403 T/A. That's a 3-bolt style with a donut, and spring loaded shank bolts. Unless they got some aftermarket style or something different.
Old Jul 20, 2022 | 06:13 AM
leftlaneonly's Avatar
I could use a donut
Old Jul 20, 2022 | 10:46 PM
Originally Posted by leftlaneonly
I could use a donut
Old Jul 21, 2022 | 06:18 AM
Burd's Avatar
Thanks, I figured all Cop cars would use the donut. Lol.
Bfg
Sep 15, 2016 05:35 AM
squirell
Mar 19, 2013 07:35 PM
delta88_frankfurt
Sep 24, 2012 06:59 AM
sixty9olds
Jun 20, 2012 09:37 AM
toneypenna
Jun 21, 2009 05:22 PM
